Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
How to re assemble - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 29, 2010
How to remove the brush roll from th assembly on a Hoover steam vac
Just pull the brush assembly straight out slightly and look for 4
release tabs....squeeze the tabs and pull the assembly out. Make
sure cord is not plugged in.
Regards,
Dennis
Sep 02, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Why are the brushes not spinning?
Hi Liz, if your brushes are still in good shape and do not need replacing then I would see if something else isn't broken or busted. You can always check for an obstruction in the brushes or remove the brush assembly & then reseat the brush assembly. Before doing so you should remove both Tanks from your Hoover. Then there are two buttons on top of the Nozzle Assembly that holds the brushes. You will need to release these two buttons on top, then tilt the handle of the unit backwards and this should let the brush assemble fall out of place. Inspect the brush assembly for any obstruction and even check to see if all the brushes still spin okay. If all looks good then align the post on top of the brush assembly with the hole on the bottom of the nozzle assembly and then snap the brush assembly back into place. I know this might sound crazy but did you first check to make sure that you did not have the switch set to "Wet\Dry Pickup." This will stop the brushes from turning as the switch needs to be in the other position to turn.
Aug 11, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Switch Assembly
Springs should be for holding top base to unit. Hook anywhere.
The roller does not spin
Hi schrim8...
Your problem is most likely a broken drive belt.
You will have to remove the vacuum base cover, then remove the roller assembly from the vacumm base to replace the belt.
After you remove the roller assembly put the new belt on the pulley inside the vacuum first, then install the belt on the roller assembly and then reinsert the roller assembly back into the vacuum base.
Reinstall the vacuum base cover.
Please take time to rate me
Jul 28, 2011 | Eureka Uno 2998AZ Bagless Upright Vacuum
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
I have a kirby legend 11, the long handle is loose, how do I tighten it please?
If it is not staying up the handle falls down then is caused by the handle spring assembly. Replace the assembly and it should do just fine. There about 7 different components inside the shell, it's usually the spring but after so many years the bushing and shaft could be bad as well. Recommend to change the whole assembly and it does require a specialty tool to tension the spring assembly.
Nov 03, 2008 | Vacuums
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozzle housing.
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
Jan 10, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
18 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
