Cars & Trucks Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2007 mercedes benz R350 battery drains everyday. Tried replacing the battery yet still the same problem. Please help
Anonymous
Level 3:
  • Master 707 Answers
  • Posted on Sep 29, 2010
Anonymous
Master
Level 3:
Answers
707
Questions
0
Helped
182860
Points
2158
The alternator is unserviceable which doesn't keep the charging system going.When the battery is fully charged the vech will run and drive for a while until it drains the charge down in the battery because it isn't being replaced by the alternator......Hope this helps.
Where can i find the battery on a 2007 benz r350
Its a big black box usually located in front of the engine either laft or right side. It has two terminals at the top.
Code U0101 on my 2007 mercedes r350
The U0101 means "Lost Communication with TCM"
_______________________
ak90 bmw key programmer
1helpful
I need a free diagram for 2007 mercedes benz serpentine belt
Should be under the hood of your car in the front.
3helpful
THE BATTERY IN THE ENGINE COMPARTMENT
if your car is left hand drive battery under the front passenger seat, if your car is right hand drive battery is under the driver seat is this information helped you?
I have a 2007 Mercedes R350. Both rear brake bulbs blew out at the same time. When I replace them they both immediately blew out again. Any idea what can cause this?
The foil where the bulb socket connects goes bad. They make a retrofit socket replacement solution. You will have to tap into the #6 wire (labeled on socket) for the drivers side and the #1 wire for the passenger side. Mercedes has a bulletin on this but refused to recall as of 2/1/2011. The parts at Mercedes are about $23.00 each side. Easy fix.
7helpful
2answers
Where is the battery located
hi there are 2 on this vehicle, the main battery is under the passenger seat, and you have an auxiliary battery in the passenger foot well area, hope this helps please vote thanks
1helpful
How to reset computer,when you change oil..r350 mercedes 2006
The answer is in the owners manual. If you don't have one the service department at the local Mercedes Dealer will probably show you for free...it only take a moment to do.
Tail lamp problems on 2006 R350
I just took my car to the dealer this morning. They changed the bulbs for free and it is working fine! take your car to the dealer unless it is out of warranty?
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
