Question about Mitsubishi WS-65908 TV
Power on for 3 seconds then shuts off - Mitsubishi WS-65908 TV
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do the self test this model has:
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
Let me know what error code is found and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 29, 2010
Testimonial: "i hope u can help me,i cannot afford another tv right now. thanks"
  • 1 more comment
  • gvfleet Jan 11, 2011
    I did this test that you suggested and I received a error code of one blink pause two blinks, can you tell me what this means?
  • SD Tech
    SD Tech Jan 11, 2011
    1,2 is no error detected. Unplug set and plug back in and try turn on again, if power light goes out in a few seconds DO NOT UNPLUG SET, do self check first.
  • daurioaz Sep 24, 2011
    I tried the test and received two flashes then two flashes and it repeated...What does that mean?
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Insignia lcd tv shuts off after 2-3 seconds
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Dec 14, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Lion OS; can't shut down, Neo Office blocks quit command on MacBook
Hi Marvin.press the power button for about 10 seconds and the mac will shut down. Make sure it's 10 seconds and not 3 seconds.
Jan 03, 2012 | Apple Tacoma Computers & Internet
I need the codes for a Sharp Tv for my Big Matters Jumbo Universal Remote. Can you help me?
here's the codes to your sharp tv for that remote
Sharp TV:
013, 028, 035, 073, 075, 078, 092, 093, 120, 131, 132, 134, 139, 141
1. T urn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (just try one of the codes I listed above) if one doesn't work just try the next one,
3. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the POWER button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Feb 28, 2011 | Televison & Video
PLEASE SENT ME ASAP THE PROGRAMMING INSTRUCTIONS FOR THE 538744 REMOTE CONTROL anitilla41@hotmail.com. thank you. asap!
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Thanx
Jul 28, 2010 | Brookstone 538744 Remote Control
I have a hp omnibook 4150 it beeps 1-3-3-1 but does not power up whats wrong
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 04, 2009 | HP OmniBook 4150 PC Notebook
Starts for 3 seconds then shuts down
maybe you have short circuit on it.
the POST see that your laptop is unable to power up. this is because of any problem in hardware
May 18, 2009 | Dell Latitude D610 Notebook
IBM Netvista powers up for only 3 seconds
if you have to wait some minutes to restart it, that is overheating...try putting a ventilator (the bigger the better, the thing here is give lots of air to the processor > CPU) and see how its working...
Jan 08, 2008 | IBM NetVista PC Desktop
Mitsubishi WS-65908 TV Logo
436 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
