Question about Singer 1507
How do i put threed into the bobbin and keep it from not getting tangled?
    Problem Solver:
  • 6 Answers
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Posted on Feb 06, 2011
Husqvarna Viking Designer Diamond I get the following error code: Remove any thread under the stitich plate and in bobbin area.
Can you get any other codes in the window or is this the only one that keeps showing up? You may need to put a new needle and bobbin in as they may have been damaged even slightly when things got tangled. Kate
Feb 04, 2014 | Husqvarna Designer I
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
Bobbin casing
Wise not to use it until you have the proper slide plate
Jul 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
I can't keep the lower thread from getting tangled. I have rewound bobbins, cleaned the bobbin case, made sure the bobbin case is in the correct position, and played with the upper thread tension. When...
Ensure that you have routed the bobbin thread properly. Also, if the bobbin case is not installed properly it will give you this problem. Ensure that the protrusion is touching the spring on the body of the machine.
Jan 27, 2010 | Brother CS-6000
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
How do i put bobbin inand were do i put yhe threed
the bobbin should fit under the steel plate you'll have to make the needle stay up to remove the base plate
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
May 05, 2009 | Sewing Machines
Singer 1507 Logo
222 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
