My Protron PLTV-26 will power on(light goes from red to green) and I see the screen briefly, then it goes into standby (light turns yellow) and stays.
  • 2 more comments
  • jg_grintech Sep 29, 2010
    I am a former Electrical Engineer and studied TV repair once upon a time. I have a scope, multi-meter, and soldering gun. Can you point me in the right direction?
    Ok, will do and will keep you posted.
    Thanks!
    Ok will do
  • jg_grintech Sep 30, 2010
    So what you are saying is that the power supply is "crow-barring"?
  • 12,061 Answers
Http://nettopdf.info/download/pdf/Service%20Manual/aHR0cDovL3d3dy5tYW5hZ2VteWxpZmUuY29tL21taC9saXNfcGRmL09XTk0vTDA2MDQ4OTEucGRm
www.managemylife.com/mmh/lis_pdf/OWNM/L0604891.pdf
Above are your service manuals.
This is a fairly classic switchmode power supply, I see this type of fault very frequently in my shop. The special fault detection circuitry in the PS, is shutting the set down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power. In my professional recommendation, you should get a "Quote" for repair, from, a, Proton Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
There are many, many types of "Faults" that can cause this, so the issue must be troubleshot.
Below is the link for Proton.
www.protonav.com/
Posted on Sep 29, 2010
  • 5,138 Answers
Remove back and look on Power supply board for Bad Capacitors they will be vented,swollen,or puffed up on TOP.
2200uf 10v 3300uf 10v
    President:
  • 2,777 Answers
This is definitely an indication of major hardware failure inside the TV, most likely the power board, but it is hard to say with certainty. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
  • Tim Grayson
    Tim Grayson Sep 29, 2010
    Alright the first place to start would be to open up the TV and check all boards, especially the power supply board which you should be able to easily locate, it's where the power first flows to. Look for bulging capacitors or any other obvious issues like that. From there follow the flow of power and check for obvious damage like capacitors... those are the most common things to go, see if a cap somewhere is bulged or blown.
    Let me know!
    Tim
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
My pltv 26 plugs in i have turned the switch near the power plug on the standby light comes on but when i push power it turns green for a second or two then shuts off
Sounds like a built in protector kicking in. Something probably has shorted. Try disconnecting the inverter (should look like this: http://marcoselectronics.com/images/48.V1448.001.JPG) to see if you can get the TV to power on without a picture. Be careful - this is a high voltage board.
Sep 26, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
No picture on TV
First place to look will be the power supply module, check the 5vdc standby voltage and all other voltages as well.
http://www.shopjimmy.com/catalogsearch/result/?q=Protron+PLTV-26
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 07, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron 26' t.v
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Doesnt work
Unfortunately, Protron LCD's are very low quality, mine went out in 15months. Your problem may be similar to one I had & I fixed it by cycling the on/off switch next to where the power cord goes in the back of the TV. Also make sure the power cord is inserted right since the "yellow" light indicate powering up but not full power. Hope this fixes it since I couldn't find ANYONE that services/repairs PROTRON brand.
Nov 12, 2006 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
