Question about LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755
I recently purchased an ice maker installation kit for my LG Refrigerator. I installed it and it doesn't seem to be working. I get no ice. Also, I don't even hear any sound of the ice machine working. There is water in the line. I have unplugged the refrigerator and turn the ice maker on/off switch several times, and still no ice. I tried to lift the arm on the ice machine, but it always seem to want to stay in the down position. I don't know what else to do. Did I miss a step? Is there a button or knob I need to switch in the back? Can you help? Thanks, John
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. back.
Posted on Mar 22, 2007
  • 210 Answers
SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Posted on Jun 03, 2008
SOURCE: My new refrigerator's ice maker and water dispenser doesnt work
Its probably way too late, but ours was delivered / came with the water pipe being crushed at the front right at the bottom of the fridge/freezer. So I would check the full length of this small diameter pipe.
Posted on Oct 21, 2008
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
SOURCE: LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Posted on May 07, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Ice making parts need to be rescrewed into mechanism
Refrigerator Repair - Replacing the Ice Maker Shut-Off Arm ...
? 8:09
Mar 19, 2013 - Uploaded by PartSelect
SourceCode=15 Click here for more information on this part, installation in... ... Refrigerator Repair ...
Replacing the Icemaker (Whirlpool Part# 4317943) - YouTube
? 5:51
Apr 5, 2011 - Uploaded by PartSelect
Refrigerator Repair- Replacing the Icemaker (Whirlpool Part# 4317943) ..... snap the circuit board cover onto ...
How to Install a Refrigerator Ice Maker Kit - YouTube
? 2:49
Jun 26, 2015 - Uploaded by searspartsdirect
Leave the mounting screw loose. Install the mounting screws into the side freezer wall leaving enough ...
Jan 01, 2016 | LG Refrigerators
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Apr 01, 2013 | U-Line Refrigerator Ice Maker
LG LRSC21934 ice maker/water dispenser doesn't work
If your house water supply to the refrigerator is poor it is most likely the cause of the water dispenser and ice maker not working. If you hear the water valve humming when the water dispenser is depressed and no water is dispensed it is most likely poor or restricted water flow to the refrigerator.
If you live in an older home the water supply shutoff valve to the refrigerator is usually in the basement or under the kitchen sink. Many shutoff valves are called a saddle valve and the valve is secured onto a cold water pipe and as the valve is turned clockwise a pin punctures the water pipe allowing water to flow. Saddle valves often become clogged with minerals and can completely block water flow to the refrigerator,. If the valve is corroded on the outside it should be replaced. Ice maker installation kits are available at most hardware stores. Copper water line kits are preferred. Cost is under $25.00. If the Saddle valve is in good shape they can be taken apart and cleaned. Be sure to shut off the main house water and drain pipes before attempting to clean.
Newer homes may have a water box in the wall behind the refrigerator. Sometimes these can become clogged with mineral deposits as well.
Hope this helps.
Oct 30, 2017 | LG LRSC21934 Side by Side Refrigerator
My LG refrigerator has the ice maker hooked up to the hot water heater, is this right. MY HOT WATER HEATER HAS SLUDGE IN IT THAT IS GOING INTO THE ICE MAKER AND MAKING FOUL SMELLING AND TASTING ICE. ...
Having ice maker hooked up to hot water side is common practice...because the water is heated before it gets to be sent to the ice maker, it would have less air in the ice...kinda like a crude way to distill the water.
The sludge is from mineral deposits in your water...sometimes called hard water.
One of the best investments in areas of hard water is a water softener system, in-line water filters, or a combination of both.
Ya might look to see if there is a filter in the refrigerator to filter water before it gets to the ice maker as well.
Hope this helps...
Jul 24, 2011 | LG Refrigerators
I have a new refrigerator and the ice maker is not making ice however it is water in the feed water line. Actually, I got a few small pieces of ice since I got the refrigerator installed last week. Also,...
Listen, if the unit is not working the way it is supposed to call and have it replaced. You paid good money for a good working refrigerator and now it is incumbent on you to insist on a replacement of another new working one.
Sep 03, 2017 | LG LFX23961SW Bottom Freezer French Door...
Have a top freezer MOD # ET4WSKXSQ01.. SER#VSW3914735
The ice maker kit you need , is IM1 kit . This comes with an icemaker , tube , water valve and everything needed to install . Instructions are included .
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Recently (last week) purchased a KBRA22KSMM,need ice maker kit
I researched this for you in my data base. Man, this is a new unit. It suggested to use a IC13B.kit. The best price I found is at they are asking $59.97 plus shipping or if there is a hhgreg around, you can save shipping but will then pay tax. This is a brand new kit and I have not seen one of these yet. From what information I can find, it does come with every thing you will need to install in your unit.
Just a reminder.
Don't forget the water supply. If your replacing a fridge that had a ice maker or water in door. you will already have a supply. If you are going to have to run one, I suggest that you spend the extra few dollars and get the copper rather than the vinyl set. Good luck.
Oct 19, 2009 | KitchenAid Refrigerators
No water toice maker
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
LG French Door Cabinet Depth Refrigerator 21 Cu. Ft. - LRFC21755 Logo
102 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
