Question about Carrier 38CKC036 Air Conditioner
Can i use 38ckc036-5 to cool walking box size 16 ft.x7 ft by 8ft.high down to 30degree temperature all year around.winter and summer.
  • 455 Answers
NO! that unit will NEVER reach 30*f cold.The refergerant used does not run(operate) that cold.
Posted on Sep 29, 2010
What size coil fits this
The 70 stands for 70,000 btu and the 16 stands for 1600 cfm.. Air conditioning requires 400 cfm per ton, so the blower is capable of delivering enough air for a 4 ton a/c unit. However, the blower is is amultispeed and has a 'blower chart' in the manual that will give you an idea of air flow delivered on all 4 (usually) speeds. You wouldn't want to deliver 4 tons of air across a 3 ton coil. That would effect the temperature drop across the coil and also effect humidity removal.
4 tons of a/c is a considerable amount of cooling, so unless you have a large space or extremely high average summertime temps, I would ask a local contractor to do a heat load calculation to properly match a system to your specific needs.
Every area has a 'design temp' around which a system should be designed. Here in the St Louis area, the design temp for the winter is 5 degrees and for the summer its 95 degrees.
70,000 btu in gas equates to 20 kw in electric heat for what its worth.
Jun 15, 2014 | Comfortmaker G8MXN0701716A 66,000 BTU 80%...
What should I do in order to make sure my dog house stays cool in the summer?
In order to keep your dog's house cool during hot summer days, consider to do the following:
  • Place the dog house in the shade so it doesn't get too hot from the sun.
  • Make sure that the house is ventilated so warm air can come out.
  • If it gets really hot inside the house, you should put a fan to cool the house down or buy a small air conditioning unit made for dog houses.
  • Place a cooling mat on the ground of the house. This will help the dog to cool down during the hot summer days.
Oct 25, 2012 | Dogs
I have Hawkins ceiling fan. How do I switch blade directions - between warm weather (counter clockwise) & cool weather (clockwise)?
Clockwise on high for Summer. Counter Clockwise on slowest speed for Winter, to get the heat off the ceiling. A good way to remember which direction it should go from season to season , is by the directional switch on the side of the fan.. Switch Up for Winter. Switch Down for Summer.
Hope this helped you. Please let me know. Thanks.
Jun 11, 2011 | Hampton Bay Heating & Cooling
Clockwise, counterclockwise which is the summer setting?
Ceiling Fan Direction These recommendations depend actually on the height and size of the room; the season; and the activity taking place in the room.
The basic fact of nature is that warm air rises to the top and cold air settles on the bottom. Air settles in layers from warm at the top to cold at the bottom, if left alone at equilibrium.
Ceiling fan recommendations:
In the winter
Set the fan to run counterclockwise (reverse; this looks clockwise as you are looking up). This will redirect the warm air from the ceiling and down the walls and into the living space where the people actually are. In a house, you would run the fan at a low speed so that you don't actually cool the warm air that you are moving downward. If you have a high ceiling, or are trying to heat a hall or a church, you may want to increase the fan speed so that the warm air will reach the living space as long as the fan speed does not create an unwanted downdraft at the people below. In the summer
In a room of normal height (8 - 10 ft), you should operate your fan so that it turns clockwise (this looks counterclockwise as you are looking up), causing a more directed downdraft, especially with the fan running slightly faster. This causes a wind-chill effect because the skin evaporates slight amounts of water from the sweat glands and thereby provides cooling through the skin's surface. However, the air is only moved but not cooled! You may find that you can turn your thermostat down a degree or two and save more money on energy costs. The air blowing down won't actually cool the room though, so you should turn the fan off when there are no people (or animals) in the room. In a high hall or church
It may be best NOT to run the fans at all in summer. This lowers the demand for cooling since the hot layer on top is an excellent insulation between the cool air near the floor (and the people) and the hot roof and outside.
A large, tall manufacturing hall would typically have different goals. There one would have a floor full of heat producing machinery plus the people operating it, working hard and welcoming a bit of a breeze. Then it would make sense to run the fans at fairly high speed to create a certain and directed downdraft. And with the shifts going throughout the days of the week, the fans should be running all the time and maybe in all seasons.
Finally, fans typically use 80-100 watts. When used properly, ceiling fans can really help to optimize the comfort level of the people and save energy and money.
Good Luck and please rate 4 thumbs up for the free answer
Jun 13, 2010 | Hampton Bay 13087 70450 Carousel II...
My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
Jun 12, 2010 | Dometic RM2652 Refrigerator
My astoria aep2 boiler seems to be running a lot. Is 20 seconds every 2-3 minutes too much. Could I have a leak. I can't hear one but would the steam wand valve cause this or could the thermometer be...
Three thing can cause this problem.
First is as you mention the air valve is leaking and is only due to its 'o' ring which can be replaced or replace the whole air valve. Not any steam should be leak from it at all.
Second during winter the water supply is much colder than summer so every boiler refill then boiler heating automaticaly switch on.
Third also during winter the room temperature is lower so the boiler is cooling down faster than summer since their in not any insulation around it.
If the presurestat which control the temperature inside the boiler become more sensitive because of years of work this is not actualy a problem since is use the same energy but now in more times and more frequent but for less time each time. Unless it stuck and either you have continues heating with no stop or stuck at alway off so the machine is always cool no need to replace pressurestat.
Feb 04, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Refrigerator won't work after winter shut down at camp
This is a problem we frequently run into in a situation such as yours. Refrigerators are meant to be used in continuous operation. Using them seasonally will let the high side condenser tubing, internal to most cabinets, rust through and loose the refrigerant charge.
May 03, 2008 | Kenmore 73503 Stainless Steel Bottom...
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Carrier 38CKC036 Air Conditioner Logo
112 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
