Question about NetGear WGR614 Wireless Router
Every light sets green except the internet connect light which is orange and it doesnt respond to anything ive tried switching ethernet cables rebooting just the internet connection doesnt work..
    President:
  • 1,768 Answers
1. Here is the user manual found at this site.
ftp://downloads.netgear.com/files/wgr614v5_ref_manual.pdf
save to hard drive >> desktop and read the "troubleshooting Tips " section page 3-8
check your router connections >> Ethernet cord to the LAN port in the back or the router to the computer.
Ethernet cord to the WAN Port from the DSL port
Posted on Sep 29, 2010
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Just got a qwest pk5000z when plugged in power light stays solid green, dsl light stays solid green, then I receive Internet connection.. After about 30 seconds it resets and starts the whole process over....
Are you using the RJ45 ended Ethernet cable?
I've been battling an issue where an Ethernet cable plugged in caused the PK5000Z to reboot approximately every 120-300 seconds (2-5 minutes).
Switching to just the wireless and not having any Ethernet cables plugged in resolved the issue.
Unfortunately this won't work for me since I only use the modem as my gateway to the internet and actually have an Astaro Secure Gateway Firewall that connect to the modem via Ethernet. I'll be contacting their technical support again tomorrow as I've had 3 modems RMA'd and not a single person there at Century Link could figure out what to try except to keep RMAing them.
So anyone else hitting this issue, try using just the wireless instead of the Ethernet Cable.
Jan 24, 2012 | Computers & Internet
My linksys network switch is not connecting network computer, what can i do to get it back to work?
Do you have any activity lights on the Linksys? If not your switch has no power a hardware problem. Try to power off for 5 seconds and restore power on the Linksys unit. Try to shut down (do not restart) all computers. Are all the activity lights off? If not again power off the Linksys for five seconds and restore power. Power on the computers and verify the activity lights are now green for each computer. If the computers are not networked and the activity lights are green, check your network settings on your computers, which could have incorrect TCP/IP settings or workgroup. If one activity light is not green for that Ethernet connection, check your cable connection or replace the Ethernet cable. The workgroup should all be the same name. The TCP/IP address should be the same with the exception of the last set of host digits which should be unique to each computer address.
Jul 27, 2010 | Linksys SR224 24Port Ethernet Switch
Netgear Router WGR614 Problem, 1234 Lights Lit Orange, No Connect
Try resetting the Netgear back to the factory default and then configure the wireless setting.
Press the pinhole RESET button on the back of the Netgear until all the LEDs flash then connect a LAN cable from the computer to the Netgear open a browser and enter the configuration URL IP address
http://192.168.0.1
Jan 01, 2010 | NetGear WGR614 Wireless Router
Manually address internet ethernet ports
crossover cable is used when you want to connect two computers.... i am giving you the ethernet cabling standard using which you can connect two pc's ...easily.
one end will consist of the following combinations...
white - green
green
white - orange
Blue
white - blue
orange
white - brown
brown
the other end will consist of the following combination
white - orange
orange
white - green
blue
white - blue
green
white - brown
brown
Dec 29, 2009 | Microsoft Windows 98 for PC
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
When i turn my computer on the big button which is usually green doesnt work. there is a smaller light which is also usually green just below the big one which starts green as i turn it on and then it goes...
Make sure your cables are all firmly connected. Also check the power strip or surge protector. If all is connected well and the pc will still not turn on it looks like the problem is the power supply unit, which can be replaced for around $20. I hope this works :).
Aug 16, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
Modem and computer are not communicating.
Are all your connections in the appropriate place? Did you press and hold the re-set button on your router for 40 seconds and wait until all the lights are green on your router?
Jun 27, 2017 | Computers & Internet
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Internet
Well, I understand that the modem is SS4100, which means ther are
5lights on it being, Power, Ethernet, DSL, Internet & Activity....
Note:The trouble shooting is done according to the Light Status on the modem.
1. No matter what the proble is, the first step is to Power Cycle the modem to eliminate the static on the modem(to switch it off and back on).
2. If the Power Light is anything other than a solid green, then the modem is fried(except the fact that the adapter is plugged and working).
3. If the Power is green and Ethernet is off, then check for the LAN cable at the back
of the computer if its connected to the modem.(It turns green if connected properly)
4. If the DSL light is anything other than solid green, then call up the ISP tech's to ask why the intenet is not working.
(make sure the DSL cable is plugged firmly onto the back of the modem and the wall jack)
5. If the Power, Ethernet and the DSL is green and the internet is not, the open up the Modem page(type 192.168.0.1 in the address bar and enter for the modem page), and cross-check for the username and the password. Save the changes and your internet is working!!!
6.  The Activity light usually blinks green and it does't have much to do with the troubleshooting.
The above are the basic troubleshooting steps.
Hope it solves your problem......
Dec 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
NetGear WGR614 Wireless Router Logo
268 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
