Question about Manitowoc MAN-CVD2075 Condenser Unit Remote Air Cooled Models QR DUAL0 QD DUAL2C and QY DUAL4C
I HAVE AN MANITOWOC Q SERIES CVD 2075 UNIT RUNS FOR 30 MINUTES AND ONE OF THE DUAL FANS CUTS OUT CAUSING INSULATION TO BURN OF HOT GAS LINE PLZ HELP
  • 884 Answers
Can you wire both fans in to the full time circuit so they both run at once?
Posted on Apr 22, 2014
    Novelist:
  • 112 Answers
Sounds like a bad headmaster valve, bad fan motor, or bad pressure cycling switch for the fan motor. Will need to know operating pressures to troubleshoot. Not really a DIY job unless you have some experience.
Posted on Dec 11, 2010
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
Husqvarna 345 chainsaw cuts off when hot
It sounds like it may be getting lean at that point, and it could be something like a tank vent. When this happens, open the filler cap, close it, and see if the saw will start.
Another easy test is to fill the tank completely in the event that a small hole has formed in the fuel line inside the tank. I doubt that is the problem, but worth the time to check before moving on to other tests.
If that doesn't work, disassemble the carburetor and clean all passages with non flammable brake cleaner (carburetor cleaner can damage check valves and soft small engine components). Sometimes dirt can accumulate in places that affect how the diaphragm moves.
If none of this works, have a service shop evaluate the unit. Pressure and vacuum tests will reveal the culprit(s) and determine if the saw qualifies for service.
Mar 22, 2014 | Husqvarna Garden
Runs and cuts, when you cut it off it will not start again for about 30 minutes
hi
everything being = with good compression and fuel system and clear muffler
sounds like you may have a faulty tank breather or a ignition coil breaking down when hot
check tank breather , then test coil hot with a spark tester in line with plug cap and plug ( must have 6 mm gap between tips of testerwhere the spark jumps across) under load when the unit does it again if no spark faulty coil , replace it should bee good to go
cheers hope it helps
pauly46
Jan 16, 2011 | Poulan Pro Chain Saw 46cc 20"
Condenser motor cuts out and causes insulation to burn off hot gas line why?
you mean the fan motor? if power cuts out to it, check sensors or the board. if power is there, replace the motor
Sep 29, 2010 | Manitowoc MAN-CVD2075 Condenser Unit...
Finned tubes get too hot all thermostats and controls chech out o
Sounds like you might have an elevation vs gas burn issue. If you are using a unit not designed for the elevation it is installed at, the unit can burn incorrectly causing the problem you are reporting. Hayward as well as other manufacturers make units to operate from sea level up to about 2000-3000 foot and units designed for higher elevation. It has to do with burn rates and proper gas mixture with oxygen. higher elevation has less oxygen and thus need different size gas orifices. It also is important to make sure you are using a Natural Gas unit with Nat Gas and not propane. Propane burns much hotter and requires smaller orifices. This can also cause premature burn out. Check with Hayward to determine your unit qualifications vs location of installation
Apr 13, 2010 | Hayward Pool Products Hayward 250k Ng H...
Runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Jul 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Mazda etude 160ie a/c cuts out after approx 45 min driving.
Could be an electrical part that only fails after getting really hot. Coils and ignition modules are known for this. Unfortunately, these parts cannot be tested for this heat-soak type problems, other than to see if spark quality at the plugs has degraded when failing. One other thought. A bad gas cap which is not allowing air to flow in as gas is used can cause this and that is a cheap part to replace just for grins.
Jan 10, 2009 | 2003 Mazda MPV
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Manitowoc MAN-CVD2075 Condenser Unit Remote Air Cooled Models QR DUAL0 QD DUAL2C and QY DUAL4C Logo
147 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
George Merkley
George Merkley
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
