Question about Toshiba Satellite L300D-ST3501 Notebook
My computer will not start-up.both power and battery indication lights not on when power is switched on.power input and battery confirmed good.processor suspect faulty,please confirm.
    Problem Solver:
  • 8 Answers
If the lights do not come on when the ac adapter is plugged in , it may be as simple as a dead power supply. use a voltmeter and test the output of the adapter at the plug. + into the hole and - on the sleeve exterior. if no reading, or very low replace the adapter. If ok i'd check the ac jack on the laptop. they are fragile and if its loose it will need to be resoldered. Try moving the cord at the jack when plugged in and see if the lights come on.
Posted on Sep 29, 2010
Is there a power input fuse on a Toshiba Satellite C655D?
no, there is no internal fuse, unfortunately- because this sounds like a dead motherboard. the aftermarket power supply could have been over-volting, or delivering unsteady power- burning the motherboard.
OR the old power supply shorted, and blew the motherboard's power circuitry, and you were just running off battery power when you first got the replacement.
please keep in mind that, at times, the physical power input jack on laptops can also break, or come loose from the motherboard.
Dec 29, 2014 | Toshiba Satellite Computers & Internet
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Izip electric bike wont start
If the battery cells have been load tested and found OK then You need to trace the output voltage (using a voltmeter) from the battery to the controller to confirm you have voltage at the controller when the power is switched ON. If there is no voltage at the input to the controller then trace the voltage on components between the controller and battery, such as the switch and fuse and all the connectors.
If there is full battery voltage at the input to the controller then suspect the controller is faulty.
Jun 09, 2012 | Electric Cycling
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I have a Model M40X that only turns on power light after switching on then starts the fan for 4 seconds hd and dvd lights just flash once then nothing no boot screen just the power light. 1 out of 25...
There are many things that can cause this type of symptom.
Is it failing on battery only? May need a new battery.
is it failing when plugged into the power adapter?
The adapter input jack will fail over time and need to be replaced.
There is considerable mechanical stress on this part, and It will fail where the jack is soldered to the circuit board.
Internal circuits can fail. Maybe a new laptop will be cheaper than repairing this one.
Oct 05, 2017 | Toshiba (K000002020) Motherboard
Ups starts beeping
Is there any indicator lights ON showing the fault condition?
This could indicate that the battery has a low charge. Even if you switch off the mains supply and it switches over to the battery, the UPS may shut down after a short time as the battery power (charge) runs out.
If the battery is more than 3 years old then it may be due for replacement.
May 10, 2010 | Powercom BNT-1000AP (dspcmbnt1000ap) UPS...
Acer 4200 wireless switch
I have copied a portion of the user manual that shows the location of the wireless switch which is on the front edge of the computer.
From left to right on the front edge of the lower portion of the computer (Not the display) The wireless switch button is the third switch from the right. Or just to the left of the power indicator light. These buttons are located in between the speakers. The buttons and lights are described below. a link to the download the complete user manual to PDF is located below.
# Icon Item Description
1 Speakers Left and right speakers deliver stereo
audio output.
2 Bluetooth
communication
button/indicator
Enables/disables the Bluetooth function.
Indicates the status of Bluetooth
communication.
3 3G switch/indicator Enables/disables the 3G function.
Indicates the status of 3G communication
(for selected models).
4 Wireless
communication
button/indicator
Enables/disables the wireless function.
Indicates the status of wireless LAN
communication.
5 Power indicator Indicates the computer's power status.
6 Battery indicator Indicates the computer's batttery status.
7 Microphone-in jack Accepts input from external
microphones.
8 Line-in jack Accepts audio line-in devices (e.g., audio
CD player, stereo walkman).
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Please let me know if I can assist you further with this question by replying to this message.
Brian
Jan 29, 2010 | Acer TravelMate 2300 Notebook
Computer will not power up when front panel button is pressed.
Input power has been confirmed? From your home outlet? Or from your computer power supply? I think your computer power supply is bad.
Jul 10, 2009 | Dell 16X Internal DVD-ROM Drive for...
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Toshiba Satellite L300D-ST3501 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
