Question about Abit AN-M2HD Motherboard
My motherboard wont start, though the power light is on
    Problem Solver:
  • 11 Answers
Try changing thr ram into another slot in the motherboard.it might be ram's problem.
Posted on Sep 29, 2010
Pc wont start up
Even though the fans are running it doesn't mean the power supply is ok. Buy a PSU tester or bring it to a computer shop to have the power supply tested.
May 19, 2012 | ASUS AI Lifestyle P5N32-E SLI...
The computer wont start up, i can see a green light on the motherboard and nothing else. even the power button wont show up led light.
This can be a power supply problem or a motherboard problem.
One or the other has probably gone bad and must be replaced, if this is what happened.
Start by disconnecting all things from the motherboard except the CPU and memory.
If the system starts, then you've ruled out the power supply, CPU, motherboard, and memory.
If not, remove the memory and see if it tries to start. If so, then the problem is the memory.
If not, then it's definitely the power supply, CPU, or motherboard.
Aug 03, 2011 | Intel DH55TC Motherboard
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
Computer powers up but wont display anything or respond to any buttons. HDD light flashes along with the CD drive. The problem started after holding down the power button for 5 seconds to do a emergency...
Weird though I dought that had anything to do with it. I would start by replacing the ram this will cause a no video boot as will a bad or overheated cpu. First b4 u spend money on the ram try hooking the external VGA output to another monitor see if u get boot screen. If not then start with the ram. If that doesnt fix it it may be a faulty motherboard which means time for a new laptop. Always get a shop to look at it b4 u trash though....
Aug 13, 2010 | HP Presario V5315WM (RG325UAR) PC Notebook
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
SUDDEN POWER FAILURE
The light on the motherboard will be on as soon as you plug the power supply in.
If, when you turn on the computer, the fan in the power supply does not start, your power supply is bad. In my experience, the switch in an ATX machine does not go bad--it's just a device to close a contact. If you really want to check it, though, find the place on the motherboard (lower right side as you are looking at the board with the top of the case away from you) where the wires from the front panel are plugged in--the ones that say pwr switch or something like that. When I do this, I remove the wires from the motherboard and short the two prongs where the wires were fastened.
In all probability, though, you need a new power supply.
Feb 05, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Computer wont power up eve though it getting power
hi i am enver parson a FixYa technician can you tell me if you have reasently changed any of your pc components and if you did wot was it
Dec 07, 2008 | Computers & Internet
Thinkpad r40 wont reboot
Batteries can develop a dead short and cause a no start. Try starting without the battery. Other things you can try is checking the power supply with an ohm meter,or plug it in and stick it in your mouth, but me personally, I'd use the ohm meter. Also check the memory, a faulty memory chip can cause this. If none of these work, them I'm afraid the problem may be with the power management chip on the motherboard. If the pm chip is malfunctioning, then motherboard replacement is your only option.
Jun 28, 2008 | IBM ThinkPad R40 2722 Notebook
Wont boot up
try to change your RAM,if same also
try to change your graphic card if u use it...
happy trying..
good luck..
Apr 17, 2008 | E-Machines eMachines Desktop PC
Cannot start
3a5bf37.jpg Try to check the Clear CMOS jumper setting near to the CMOS battery it could be possible replaced or removed to its default settings, its is a 3 pin jumper pin 1 , 2 should be the default setting to that motherboard.
Jan 16, 2008 | ASUS P4V8X-X Motherboard
Abit AN-M2HD Motherboard Logo
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
