Error-message states that my sdhc flash-card is write protected. how do i make it un-write-protected so i can download more stuff?
  • 90 Answers
There might be a little switch on the sd card if there is switch it the other way
Posted on Sep 29, 2010
Testimonial: "thank you sooooo much. i'm up and running- thanks to you!!!!!"
When I try to take a picture an error message comes on the screen saying Write Protect
You neglected to specify the model of your Olympus camera so I'm assuming it's one of those that use SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Olympus Cameras
Release Write Protection
Mar 19, 2012 | Cameras
I get the message 'protected card' Next trick?
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 10, 2011 | FUJIFILM HS20 EXR Digital Camera
I accidentally used a damaged SD card on my Kodak P712, so it flashed that "error" message. but after that every SD card i used, whether my own or new, it always flash that "error"...
The problem is that your camera will only read SD cards, not SDHC cards. After you damaged the SD card that you've been using for years, you bought a replacement, not noticing that it was SDHC. The new cards don't work, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
Jan 19, 2011 | Kodak EasyShare P712 Digital Camera
When I want to take photo a message says: memory card is write protected.How can I solve this problem
Take the memory card out of your camera. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 14, 2011 | Nikon COOLPIX S200 Digital Camera
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
My r4i wont work since I updated my dsi
It's because the newest firmware blocks the R4i card, next time use google a bit more before you do a firmware update, you need to buy the
newest R4i card, the newest moddel of that flash card works again with the newest firmware.
Tip: Buy the Hyper-R4i card instead of the R4i because the hyper-r4i has
a reprogammable chip, you don't have to buy every time a new flash card, you just have to update the chip on the flashcard to bypass anny protection.
Sep 17, 2009 | Nintendo DSi Black Console
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
