Question about Thermador C302U Electric Double Oven
Oven door wont open code f53 thermador how can i get it open food is in it
  • Thermador Master
  • 2,605 Answers
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
  • radiohead219 Dec 29, 2010
    did not work for me, door still locked!!
  • Helene
    Helene Nov 16, 2016
    After you have tried the circuit breaker to no avail..restart the self clean and let it go for one minute and then stop the cycle with the cancel. Should open now.
Why do I have error code F25 on my Thermador oven error codes
clean the touchpad control panel. Make sure the oven door closes properly to prevent excessive heating of the touchpad. If these don't resolve it, it calls for a replacement of BOTH the touchpad AND the relay board. EXPENSIVE!
Aug 23, 2014 | Thermador SC272T Electric Double Oven
I have a Thermador smw272 oven that the lower oven door will not close all the way and the light stays on. I have replaced the hinges and roller assemblies three times and I still have the same problem. I...
is the door switch bad?when you open the door all the way if it is at a 90 degree angle the hinges are good also i just looked your model number up and it says the hinges are no longer available part 14-38-045-01
Nov 14, 2017 | Thermador SMW272 Electric Double Oven
How do I use the 'self clean' feature? I can't find the manual and it needs to be done
Good luck with that - whenever we use the self-clean function it goes crazy on us - beeping, error codes - door locks up - have to reset breaker to make it shut down. The last time the door got permanently locked - nightmare!!
Also, there is a recall on some of the wall units - ours of course isn't part of that recall - Thermador doesn't care that we can't open our oven - they'd rather you purchase another piece of junk!!
Oct 20, 2010 | Thermador SC302T Electric Double Oven
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Oct 17, 2008 | Thermador Ovens
Couldn't open door after using Clean Cycle Function
hi thanks for the question there should be a solenoid at the back where the lock rod comes out check there thanks the appliance doc
Sep 23, 2008 | Thermador C301U Electric Single Oven
Door is locked- F53 Error
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Aug 22, 2007 | Thermador C302U Electric Double Oven
Thermador C302U Electric Double Oven Logo
1,109 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
