Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
ENGINE WILL NOT START - Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
My power-washer suffers from same problem after sitting idle.
After paying for a new carburetor, I discovered how important it is to drain the gas if washer is going to sit idle.
Another time, we had a problem with the screen covering exhaust outlet. Deposits from the engine + dirt clogged the screen. Although it's not the solution for everybody, we broke the screen open with a screwdriver and the machine ran fine after that.
Small gas engines require 3 things. Compression, spark, and fuel. Take out spark plug. Put finger over spark plug hole and pull cord or push starter. Do you feel suction? If yes, then you have compression.
If machine will not turn over at all, then your motor might have run out of oil. Power washer needs oil in 2 places. It needs oil for the engine just like a lawn mower. Oil plugs are located low on each side of engine. It doesn't hurt to change oil, but do NOT NOT turn small engine upside down or oil will get into carburetor which requires removal and cleaning. I learned that the hard way.
The power washer also needs oil for the pump head. This is the box attached to front of engine. Usually 10W20 non-detergent is a good choice. Oil is usually about half way up inside pump head.
Now hook spark-wire back to spark plug. Hold spark plug in hand. Touch threads of spark plug to metal spark plug opening. Now pull cord or push starter. Do you see sparking in the spark plug gap? If yes, then you have spark. Put new spark plug in anyway. If no, then you need parts from small engine repair service.
Spark plug is in. Take off air filter so you have access to carburetor air intake. Put fresh gas in tank. Use starter spray or WD-40 as a starting accelerant. Set your choke to start engine. Spray starter fluid into carburetor opening and pull cord or push starter. The engine should fire up on the starter fluid. If engine doesn't fire, then try setting choke in different positions. If engine doesn't fire up then carburetor is suspect.
If engine fires but dies, keep spraying starter fluid into carburetor to see if you can keep it going that way ... and then move choke in different positions ... you might need extra hands for that maneuver.
If machine turns on, but dies when filter is put back, then filter might be clogged. Time for a new filter anyway.
Finally check the fuel filter and fuel line below the gas tank. It usually has a hex head bolt. Loosen bolt and see if fuel is able to fall out of tank. Loosen rubber fuel line at both ends and see if fuel is flowing. This will tell you if fuel can get to carburetor.
Usually these measures get the thing going or tell you if professional service is needed.
Posted on Sep 30, 2010
Engine crank but want start why?
Sounds like fuel not getting to engine.
Jun 19, 2017 | Cars & Trucks
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Jan 01, 2016 | Cars & Trucks
My Holden barina won't start and check engine light is flashing
Check Engine Light On - Auto Diagnosis Repair Help
www.aa1car.com/library/mil.htm
The Check Engine Light (which is actually the Malfunction Indicator Lamp or ... you can assume the fault that is causing the Check Engine Light to come on is probably minor and won't hinder your ability to continue driving. ... When the ignition is turned on (don't start the engine yet), the tool will .... flashing check engine light ...
What Causes the Check Engine Light to Come on in a Car?
www.wisegeek.com/what-causes-the-check-engine-light-to-come-on-in-a...
Nov 7, 2015 - When the check engine light comes on, take the car to a reputable mechanic .... I went to go home. the check engine light was blinking and it won't start. ... I looked in my manual book for 2001 holden barina car to see what the ...
Car cranks but won't start, Check Engine light blinking ...
www.evolutionm.net/...engine.../424408-car-cranks-but-won-t-start-chec...
Jun 1, 2009 - I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick.Missing: barina
Check engine light flashing car won't start - RX8Club.com
Dec 09, 2015 | Holden Cars & Trucks
How do you start a 19th mtd riding mower
Put your left foot on the clutch pedal and push down all the way on the clutch. Move the throttle lever all the way to the top, this turns on the choke. Turn the key clockwise, to the right, to start the engine. Once the engine has started, move the throttle lever down to turn off the choke. You only need the choke when the engine is cold. If you use the choke while the engine is hot, you can flood the engine (too much gas) and this will fowl the spark plug. If you have flooded the engine, turn off the choke by lowering the throttle lever and try to start the engine a few times. If the engine doesn't start, then you may need to wait 20 to 30 minutes before trying to start the engine again. If the engine still does not start, then you can remove the spark plug to dry and to clean the spark plug. With the spark plug out, turn the key to the start position for 10 seconds, to push out excess fuel and fumes. Replace the spark plug and try starting the engine without turning on the choke.
Oct 08, 2014 | Garden
Volvo 2005 EC210 BLC Engine Crank but no start .display shows code 140SID and 250 9
It can be faulty fuel pump or clogged fuel filter or its issue with starter or battery or may be problem with sensors.There are few possibilities that can cause these problem,there are few help links provided related to these issue. Click the link below and refer the troubleshooting procedure to solve the problem:-----
Engine cranks but will not start? http://technoanswers.blogspot.in/2012/02/engine-cranks-but-will-not-start.html
-------- Landcruiser prado won't start http://technoanswers.blogspot.com/2012/10/landcruiser-prado-wont-start.html ------- 2007 ford expedition engine cranks but wont start http://technoanswers.blogspot.com/2012/10/2007-ford-expedition-engine-cranks-but.html
: Engine Cranking Fast but not Firing up? http://whatisbyme.blogspot.in/2012/05/1999-lexus-gs300-engine-cranking-fast.html
1997 Oldsmobile Cutlass Ciera: The Engine cranks but not start? http://schematicsdiagram.blogspot.in/2012/04/1997-oldsmobile-cutlass-ciera-engine.html
Mazda MPV cranks but will not start? http://technoanswers.blogspot.com/2012/01/mazda-mpv-cranks-but-will-not-start.html
-------- MAZDA MPV WILL CRANK BUT NOT TURN OVER TO START? http://technoanswers.blogspot.com/2012/01/mazda-mpv-will-crank-but-not-turn-over.html
--------- Vehicle Cranks Fast but Won't Start http://whoisbyme.blogspot.in/2012/07/vehicle-cranks-fast-but-wont-start.html
How to test Crankshaft Position Sensor? http://fordrepairhelp.blogspot.in/2012/03/how-to-test-ford-focus-crankshaft.html
These details will help,keep updated for more help.
Oct 16, 2012 | Cars & Trucks
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
My car turns over good, acts like it might turn on then continues to turn. I figure it might be fuel filter since low fuel light had come on.Or could it be th fuel pump got hot and is not working properly?
common problem is turning car off with engine not reaching normal operating temp and floods engine. try this. DE-CHOKING PROCEDURE WHEN ENGINE CRANKS BUT DOES NOT START
If the engine does not start, try the following procedure to start the engine using the de-choke mode.
Failure to do so may aggravate the no start condition.
1. Depress and hold the accelerator pedal to the floor and crank the engine for 7-8 seconds. (This will clean out any unburned fuel from the combustion chamber)
2. Release the ignition key to stop cranking.
3. Release the accelerator pedal and start the engine. If the engine starts while performing Step 1 the engine will rev up. Immediately release the ignition key to stop cranking and remove your foot from the accelerator pedal.
^ Do not keep holding the ignition switch in the START position over 10 seconds if the engine does not start. This may result in a weakened or dead battery.
^ Avoid racing the engine or sudden take off right after starting the engine.
^ If the engine still fails to start following the De-choking procedure, have your vehicle inspected by your Mazda Dealer.
for your info there is a recall for this problem. contact mazda.
May 04, 2011 | 2004 Mazda RX-8
Engine do not start
take dist cap off and remove rotor look for carbon tracking on it. have a lot of problems with no start cuz rotor is worn and fire shoots straight thru
Dec 10, 2008 | 1988 Chevrolet K1500
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
626 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
