Question about Amana Refrigerators
Amana Temp Assure bottom freezer model BB120TW---about 10yrs old; ice forming throughout freezer: refrigerator works fine. Diane Curry
I am having a similiar problem. How is your seal - check the gasket and see if there is any separation from the door where air could get in. I had our gasket replaced several years ago but the door was not level and the seal pulled away from the freezer in the upper left corner allowing air to get in and make snow in the unit. Now the compressor has trouble kicking on after the auto defrost. We hear an electric buzzing sound every 20 seconds or so. Fans run but the unit doesn't cool. If we pull it out and unplug, wait and plug back in it usually starts back up. I have read that rather than replacing the whole compressor we may be able to just replace the relay,overload and run capacitor assembly - looking into that now...
Posted on Dec 01, 2010
Amana freezer forms ice on the bottom. We have taken it apart, cleared ice from coils and drain, turned down freezer temp, but it still happens. Fridge works fine. Any other ideas?
When you see that ice forms on the bottom of your freezer it is most likely means that the drain hose of the fridge is blocked.
You will need to take the panel inside the freezer off, clear all the ice and pour hot water into the drain hole until you hear the water coming out at the beck where the compressor is located.
The next step would be running a 1/4" hose thru that hole.
Good luck.
www.QuickFixAppliances.ca
Oct 07, 2013 | Amana ARB8057CSR Bottom Freezer...
Ice crystals are forming throughout my bottom freezer
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 15, 2011 | Amana ABB1927DE Bottom Freezer...
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer is not making ice and the temp seems to be dropping.
You may have a defrost issue,Please check and see if it has an accumulation of ice build up in the back and post back.
Jan 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Crystals forming all over freezer
Sure sounds like the defrost cycle is not working. Could be a bad defrost heater, t-stat or timer.
Nov 27, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
308 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
