Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes not spinning
I have the same problem, where do I get a turbine, and why is this happening to so many machines ??
Karen
    President:
  • 1,673 Answers
The turbines get junk inside gumming up the gearing, some times you can take apart and clean everything inside. just remember where things go when you are done. Soaking the parts in hot soapy water helps to clean. When it is all dry, put it back together and try it. Replace it if it still doesn't work. You should be able to get one from your local repair shop, or they can order it for you. Maybe going to thehooverstore.com, order thru them direct.
Posted on May 26, 2008
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
5 BRUSHES DO NOT ROTATE WHEN IN CONTACT WITH CARPET
HI There,
When the brushes on a Hoover SteamVac stop spinning, it can be caused by several things. The most frequent problem is that there is debris in the brushes such as pet hair, or lint, that prevents the brushes from spinning. Usually if you remove the brushes and clean them thoroughly, this will fix the problem. This sounds to me like what is the problem on your machine, as you make it seem as if the brushes spin, but only stop spinnning when you put them down on the carpeting.
The brushes on your Hoover are driven by a turbine brush gear assembly, not a belt. Sometimes this part can go bad, but usually when it does, the brushes won't spin at all, even when they are not on carpeting.
Anyways, here a helpful guide that I've done that shows you step by step how you can diagnosis the problem with your brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine.
I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
Now look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
If you find that your turbine needs to be replaced, I have written a step by step guide that shows you each step on how to replace your brush turbine gear. Here's a link to that repair if you need to do it:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Hope this helped you, please be sure to rate my repair or leave me feedback if you found this helpful, thanks so much!
Chris Jones
GoVacuum.com
May 01, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My brushes are not spinning
Hi There,
There could be several reasons why your brushes are not spinning. Here's a step by step diagnosis guide so that you may check to see first what is causing them to stop spinning.
If you diagnosis this and find that your turbine gear is broken, here's a link that will walk you through step by step on how to replace the turbine gear assembly:
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this problem.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Apr 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Scrub brushes not rotating
Hi There,
You'll need to first diagnosis why these brushes are not spinning. When the SpinScrub brushes on a Hoover SteamVac don't spin, this can be 1 of 3 different things.
In order to diagnosis which one of the problems is causing your problem, here's what you'll need to do.
Step 1. The first and easiest thing you should check is to make sure that that the brush speeed selector knob on the top of the machine is turned on, and is not in the off position. This may sound obvious, but I've had several cutsomers that have come in with this exact problem, only for the brushes to be turned off. Also make sure that the SteamVac's handle is reclined, and not in the upright position. There's a switch inside that shuts the brushes off when the SteamVac is moved into the upright position. If the brushes still are not spinning, move on to step 2.
Step 2. You'll need to remove the SpinScrub brushes from the SteamVac. Turn the machine upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed (my left hand was holding the camera, lol), but the tabs on the left hand side are in the exact same location:
Step 3. Once the brushes have been removed, plug the machine in, make sure that the handle is reclined. Look in the SteamVac where the brushes used to be. You should see a hole that is square shaped where the brushes go into.
Turn the machine on, and look to see if this square shaped hole is spinning. If the hole is spinning, this indicates that either the brush block itself is bad, or there maybe something clogged (such as pet hair) in the brushes that's preventing them from spinning. If the square hole is not spinning, this indicates that your internal turbine brush gear has gone bad. Here's a link to a repair that I've written on how to replace the internal brush turbine gear if the square shaped, female receptacle hole is not spinning.
If the square shaped hole is spinning, here's what you may do to see if the brush block is just jammed up with debris, or if the brush block itself is bad and needs to be replaced:
Step 1. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem.
you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken. If the pole has broken, you will simply need to replace the brush block.
It can really only be one of these three things that are causing your brushes not turn. Here are links to all of the products that possibly need to purchased (if the brushes weren't just clogged) on our website for the model that you listed this repair under, the Hoover F7425-900.
- Hoover Brush Turbine Gear Assembly Part 43191009
- Hoover Brush Block SpinScrub 6 Brushes For F7425-900, Part #
48437030
I hope that this helped you figure out the problem. If you have any follow up questions, please use the Clarification Request form here on Fixya and I'll be more then happy to follow up with you and help you out. If you found this helpful, may you kindly please rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair? This is really what keeps Fixya repair experts coming back to give free repair advice, and helps Fixya users continue to get the free replies without having to pay for answers. It's greatly appreciated.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Why wont the brushes spin? I have had this machine for about 3 years and it has always worked great, tonight the brushes will not spin at all, it still sprays and sucks up the water. We took the brushes...
In this machine there is no belt. The brushes actually spin by vacuum and in the turbine assembly there is a small wheel bearign which rusts out. You will need to remove and repair or replace the turbine and gear assembly P/N should be 43191009
Feb 10, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes won't turn on my hoover steam vac dual v
Hi There,
Unfortunately the answer above is far from helpful. The filter has absolutely nothing to do with your brushes not spinning, and you can really replace the turbine yourself without having to take it into a shop to fix it. Here's a much more helpful diagnosing of how to check the brushes, and fix the turbine if needed.
There can be serveral things that may have gone wrong with your Hoover so that the brushes stop spinning. Unlike the other "expert" above I will walk you through step by step on how to diagnosis this problem, and fix it. Unfortunately there is no belt or band on this model, but instead it's actually a turbine assembly that drives this brush.
Possible Problem #1. Usually the most common problem when the brushes stop spinning is that the brushes have simply gotten clogged with something that is preventing them from spinning. Especially if you have pets in the home, this is a common problem. Here's how you can clean these brushes.
First, turn the machine upside down so that the brushes are facing upwards. Pull down on the upwards on the brushes and they will easily snap right out of the mahcine completely. . Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. It's important to make sure that the brush switch on the top of the machine is turned to "Rotating Brush Speed Hi", and that the handle of the machine is reclined down. There is an internal switch inside the machine that turns the brushes off when the machine is in the upright position, so you'll need to step on the handle release pedal to ensure that this switch is engaged. Hopefully the brushes just needed to be cleaned, and they will now work now that you have reinserted them. If this still didn't fix your problem, move on to the next possible problem.
Possible problem #2: If the cleaning didn't fix your problem, remove the brushes from the machine again. Once the brushes have been removed, the handle reclined, and the brush switch turned to fast, turn the machine on. Where the brushes were sitting you'll see a square shaped hole (pictured below) that the brush stem fits into that actually spins the brushes. This part should be spinning while the machine is on. Here's a picture of that part:
If this part is not spinning, then your Turbine Gear Assembly has gone bad and needs to be replaced. If this part spins however, then this indicates that your brush block is gone bad, and needs to be replaced.
Here are links to the exact parts for your model that may need to be replaced:
Brush Block:
http://www.govacuum.com/hov2st6blpa4.html
Turbine Gear Assembly:
http://www.govacuum.com/hostretubrge.html
Here's also a link to a Fixya repair solution that I've done explaining step by step how to replace the turbine gear:
I hope this helped you, please be sure to rate the repair or leave feedback if you found this repair to be helpful.
Thanks so much,
Chris Jones
GoVacuum.com
Jan 12, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes won't spin on a Hoover Steamvac SpinScrub Model F5918-900
well the hand tool works off the suction of the machine and has nothing to do with the turbine that controls the brushes. if you can get the part i can walk you through taking it apart. when you write back, let me know what the model num of your machine, so i can give you the right directions. hope this helps
Aug 02, 2009 | Vacuums
Brushes wont spin
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
I hope this helps you with your problem. If not, please feel free to email me at chris.jones@govacuum.com, and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I do carry all parts for your machine, and would be happy to provide any technical support you need.
I tried uploading the pictures to this solution, however Fixya will not allow the pictures because they are too big. Please email me, and I'll send you the pictures.
Chris Jones
GoVacuum.com
Oct 03, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not spin on my steam vac
Take the brush block out and see if the brushes turn of, if not replace the brush block. Otherwise it is the turbine(#23) that has to be replaced, sometimes you can take the turbine apart and clean it. The top cover has to come off, turn it over, take out the brush block, take out the screws under that, there are other screws, under where the turbine sits, there are 2 longer screws, if you don't have them out, then you missed them, there 2 screws on the front end of the turbine, unhook the koses and it will come off. This pix. may help:
Mar 02, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
