Question about Kenmore Elite 45986 Front Load Washer
My washer starts to wash then it stops and flashes HF, What does this mean?
  • 15,935 Answers
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
What does the F and H mean
Do you mean "HF"?
According to the manual HF means water inlet problem.
-Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer.
-Are faucets completely turned on?
-Are screens at inlet hose connection clogged?
-Are hoses kinked?
-Are inlet hoses frozen?
Plug in washer, re-select cycle and press START. If the problem remains, call for service.
Or you can post the problem at Repair Clinic. They might be able to help further, and they sell parts if you need.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 10, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My washer keeps flashing and saying FH or Hf ... what does this mean?
Check to make sure you are getting a good supply of water to the washer. Remove hoses at the washer and make sure the filter screens are not clogged.
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when the machine stops mid cycle and H and then F displays in the digital window?
I think that means NO, Hot water Flow (HF)
Try this Hold the "Start" button IN while you Switch ON.
Also check this out pull the water lines filters to check the screens, and the cold water line for crud in it
Feb 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Flashinf H F
check your fill hoses,,for kinks,,or clogged,,the unit is detecting no water ate one or booth of the fill hoses..clean your screens,,,onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
washer or disconnect power.
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
43 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
