Question about Car Audio & Video
2000 Toyota Tundra Limited truck 5 CD player will not play change or eject CD'S. Radio and Tape player work fine. How do I remove Unit to see what is jammed or hung up. At least to remove CD's?
  • Anonymous Mar 17, 2014
    Instructions for removing a blaupunkt radio/tape player
  • 19,396 Answers
Check here, some of the Toyota stereo models illustrated in the website will have same disassembling procedure as your Tundra.
Posted on May 26, 2008
    Sergeant:
    Champion:
  • 304 Answers
well in that case that there was no such way to open the tray.. the only thing you can do is to remove & disassemble the unit, by removing the the cover to see which is causing the tray not to came out..
`jack
  • 3,037 Answers
You need to remove all of the dash panels first, they should be attached with screws at the bottom and should pull out at the top. you should be able to access the cd player from there to remove it. Let me know if you run into any problems and if you can post any pictures if you get stuck that would be great. Otherwise any description of any problems that you run into should be good enough if you can describe the problem well.
I will be glad to help you all of the way through the process so don't be afraid to ask if you are unsure of anything. good luck
Posted on May 24, 2008
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
  • 13,433 Answers
Is there a small hole on the cd player? use a paper clip to eject the disc.
    President:
  • 2,712 Answers
Try slipping a thin plate like a putty knife down both sides of the radio. This releases spring clips and the radio should slide out.
What does error code E-01 mean? CDs won't play and cannot eject trunk unit.
thats what i do with mine ,the phone thing but error E 1 means that a cd is jammed in the unit,happens to me all the time as i only use it for jaguar meetings .Now what you do is to pull out the cartridge and remove all the CDS then re insert it and press the eject button again and it might if your lucky retrive the cd in the player and return it to the cartridge ,.then refit all the others till it happens again
Apr 29, 2015 | Jaguar XJ8 Cars & Trucks
SANYO FXCD-500 has CD Stuck inside player. Radio & Cassette Still Work. It is Still in Dash of my Toyota 4x4 Pickup. Besides taking unit out of Dash??? Any Suggestions??
Sanyo FXCD-500 Operating Instructions Manual - ManualsLib
www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
Mar 30, 2015 | Toyota Cars & Trucks
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
2007 Toyota Yaris Stereo Won't Eject CDs
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
Mar 01, 2010 | 2007 Toyota Yaris
How to remove radio faceplate on 2003 Toyota Camry?
U don't have to remove anything, just get a laser lens cleaning disk from any store that carries music CD's Walmart has them for about $6
Mar 22, 2009 | 2003 Toyota Camry
Toyota Avalon 2000 xls cd player does not work
If you are using "home-made" or "burnt" CDs, this can happen. Sometimes, you can remove the radio from the dash, and unplug it. That may reset the CD player, and the discs will eject.
It works for me about 85% of the time. Hope this helps.
Jan 15, 2009 | 2000 Toyota Avalon
Blaupunkt IDC-A09 NOT RECOGNISED?
try unplugging both the changer and the head unit, leave it for 10 to 15 mins then plug the head unit in 1st, then the changer.
let me know how you get on
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Just stopped playing CDs
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Nov 26, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
Open Questions:
Car Audio & Video Logo
190 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
