Question about Whirlpool Duet GHW9150P Front Load Washer
My front loader dryer is not geting hot - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
  • Whirlpool Master
  • 17,129 Answers
If this is an electric model then the heater must be checked for continuity as well the program controller must output with the relay.
So check these three points, the program output, the relay and the heater coil., not forgetting that the motor must run with hot hair blown.
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
When you turn the spinner on it wont work i'ts geting power to it but wont spin but pumps the water out
Check that the drive belt is on (you can find this underneath the machine if its a top loader, or in the back if it's a front loader) If the belt is on, check that the pulley turns freely, you may possibly be looking at a seized bearing or gearbox.
Jul 29, 2011 | Washing Machines
My maytag front loader gas dryer blows hot and then blows cold what could be the problem?
Hello
When the dryer wont dry clothes or won't heat at all it means that the issue is with the Thermostat/Thermal fuse that needs replacement as it has gone bad. Please check the thermostat for continuity as no continuity between its two pins states bad fuse. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE0332 Gas Dryer
My dryer will not heat up. What can I try at home before calling a repair person? It is a glass door dryer that matches the Maytag front-loader washer.
pull the vent hose off and turn the dryer on and see if there is hot air coming out, if not then it is the heating coil
Aug 12, 2010 | Maytag EPICz Electric Dryer
Maytag neptune dryer not geting hot
If your Dryer is the Electric version, then more than likely you have a burned out heating element, you can check it by first UNPLUGGING THE DRYER!!! after you have UNPLUGGED THE DRYER!!!, you can remove the front cover and check the element for continuity, the whole unit comes out as a Tube.
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Runs But wont dry
The first place to check should be the hot surface igniter. You should be able to inspect the hot surface igniter with a flashlight after you have removed the bottom front panel. If there are any white spots or complete break-offs in the igniter than it should be replaced.
If the igniter seems to be functional then it may be the thermostat that needs to be replaced.
Mar 22, 2010 | Maytag Neptune MDG9700A Gas Dryer
My front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Jun 22, 2009 | Maytag MDE9206 Dryer
The dryer gets hot but takes five hours to dry one load
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
Also make sure the exhaust vent is not over the recommended length (refer to the manual).
Let me know if you still need help.
Apr 01, 2009 | Frigidaire Dryers
Dryer geting to hot
When that happens it is usually because of a broken thermostat or a devective vent system, see : It overheats.
Nov 20, 2008 | Indesit W 123 Front Load Washer
Spin cycle
I had to have a repairman out for this problem, but before I realized that the clothes were still too wet for the dryer, my dryer actually got too hot and burned a blouse...We all have a lot to learn about these newer machines. I suggest a repairman. I wish I could help you more.
Jul 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
202 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
