Question about HP PHOTOSMART PLUS B209A All-In-One Printer
Suddenly won't print; had sat idle for few days;
  • HP Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts,
Posted on Sep 29, 2010
Intermittent revving problems/idle problems
probly shud du a data stream-shows values of system to help pinpoint prob--done w xpensiv gear at independent shops----or concentrate on throttl body--idle motor area or tps-sounds like somethin worn in the throttl opening causing it to almost close----some components cud be gettn hot causin hesistation-from circuit wear--unplug computer then plug bac in a few times-see if system reboots---haynes manual hav dtailed ngine repair-used by pros--or librarysec 629 has chilton books
Mar 05, 2014 | Dodge Neon Cars & Trucks
A wet air filter was put into my nissan sentra gxe with a 1.8L engine. It will start and idle, but won't rev much past 2000 rpm's. The filter was rmoved and the car sat in the sun all day hopi
never wash or wet an air filter as it closes up the pores in the paper element
fit a new element and then run the fault codes or reset the ECM using a scan tool
Jan 19, 2018 | 2003 Nissan Sentra
Kymco 50 2009 rough idle hesitation
Check the battery.See if the gas is bad check the gas filters.Drain the gas ,have the carb cleaned.If it sat the gas is only good for 30 days.
Oct 27, 2011 | 2009 Kymco Sento 50
Hello, I have a 99 silverado z71, I was driving along and all of the sudden it lost power and started to spit and sputter and ended up on the side of the road,sitting there it continued to idle roughly,...
Have the shop check fuel pressure at the fuel rail. Maybe the pump impeller has failed. If fuel pressure is good, your timing chain/belt may have slipped.
Nov 07, 2010 | Chevrolet Silverado 1500 Cars & Trucks
When my taurus has sat overnight...or when it's cold. When I start it, it acts like it wants to die...then it revs up all of the sudden and seems fine. The gauge goes in between 0 and 1 for a few seconds...
Without more info I would guess your Idle air control motor (iac) is going out - this component can be quickly tested at your local mechanic shop without much hassle. Hope this helps!
Nov 05, 2010 | 2002 Ford Taurus
Honda XR 200 will not idle dies suddenly when cold
Hi, Success97601 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
XR200 won idle
XR200 Won Idle
XR200R service manual repair 2000 2002 XR200 Download Manuals Technical $15
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Sep 03, 2017 | 2002 Honda XR 200
Printer sat idle for a year. Now the colors won't
try cleaning the copper contacts on the print cartridges and then thry printing....see if it helps....
Jun 24, 2009 | HP cp1700 Color Inkjet Printer
2005 Honda VTX 1300 R will not idle
Hi, Shirleypaw and the usual suspects are:
13. Faulty auto choke or wiring connection.
07 VTX 1300S won idle after adjusting screw to 2 1 2 turns out 2005 VTX1300 won stay running
Honda VTX1300S Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Feb 25, 2009 | 2005 Honda VTX 1300 R
Epson R200 print job suddenly slows down
Your printer memory is full and it needs to wait to take on more data files for printing.
Jul 13, 2017 | Epson Stylus Photo R200 InkJet Printer
Won't idle
possibly a sticking idle air control Mtr also known as IAC motor
Aug 18, 2008 | 1996 Jeep Grand Cherokee
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
162 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
