Question about Amana Heating & Cooling
Central air conditioning unit blows air but not cold air
  • Amana Master
  • 17,129 Answers
Must see if the compressor is working and if so there are no vents blocked or the fan is not working into the vent to push the air.
so check if other vents are working if so look for a block in the vent
Posted on Sep 29, 2010
  • Amana Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
4 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
Goodman central air conditioning. Little air is coming from the vents in the house and the air that is coming out isnt very cold
have the central unit blower/fan cleaned as they block up from dust and other particles so that they eventually look like logs and do not move air like they should. Have the unit gas pressure tested for correct amount of gas
Jun 17, 2013 | Heating & Cooling
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
Central air conditioning blowing out hot, not
Can you tell if your outside unit is running (the fan and compressor)? Sometimes it is hard to hear the compressor for the fan. If they are running then you possibly have a low refrigerant charge and need to have some added. Refrigerant pressures and temps can be checked to verify this. If they are not running then you need to find out why. If both the fan and compressor are not running then first make sure all the breakers and disconnects are closed. Then a bad contactor or capacitor could be the problem. If its just the compressor that's not running then it could still be the capacitor or maybe the compressor.
Apr 29, 2010 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Jul 22, 2009 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Home central air conditioning unit
check the filter, make sure it's not plugged. Make sure all the vents are open. Are the lines freezing up (have ice on them?) Could be a lot of things but if it is not blowing much air then you may have a motor problem or dirty filter. If the unit is freezing up then probably have a leak and will need to be found, fixed and recharged.
Jun 09, 2008 | APC Heating & Cooling
Heating & Cooling Logo
210 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
