Question about Husqvarna Partner K1250 Cutoff Saw Air Filter Kit
What is the guel mixture for the Partner K1250 Cutoff saw?
    Problem Solver:
  • 11 Answers
50:1
Posted on Jul 25, 2011
Buy new saw
What exactly is the problem? There should be a rubber "O" ring between the cap and tank. If you are using ethanol blended fuel, it may have dissolved, or turned to mush . In which case you should also check your fuel pick up line in the tank.
Nov 09, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Repair manual partner k750
http://speedy.sh/A7tjW/K750.pdf This should give you the shop manual
Feb 08, 2013 | Husqvarna Partner K650, K700, K750, K950,...
When cutting i think the engine is getting hot how to adj the carb
The K1250 only has a low speed adjustment screw, the main jet is fixed, if the machine idles ok there is no other carb adjustment that can be made.
Jan 19, 2013 | Husqvarna Partner K1250 Cutoff Saw Air...
Looking for year made, of a partner cutoff saw k-700,serial number..3440420need it to order parts
The K700 active and active 11 had a t bar on the side of the blade guard which you pull up to adjust it, and the cutting arm and belt guard are held with 13mm nuts, the active 111 had a plastic bracket on the top of the blade guard which you push to move the guard, and the belt guard and arm are held on with 13mm bolts.
Jan 13, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I changed fuel filter ,fuel line to carberator ,rebuilt carberator and adjusted properly put new mixed fuel and coil is new and gets good spark motor has compression motor fires and stops runinng riteaway ...
Are you sure you pump in the unit properly? Some carbs have the gasket against the carb body and some have the pump next to the body. Also check the needle valve for proper operation,and dirt.
Jan 20, 2011 | Husqvarna Partner K1250 Cutoff Saw Air...
I have a partner k1250 cut off saw and there is no spark going to the spark plug. The switch is on, and I put a new spark plug in. Do you think it might be the coil. Rich
first make sure the switch is good and the wires are not grounding anywhere this is cheper fix then a coil when the switch is bad
start simple and work up
good luck
pat
Sep 17, 2010 | Husqvarna Partner K1250 Cutoff Saw Air...
Husqvarna Partner K1250 Cutoff Saw Air Filter Kit Logo
218 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
sgtstrat
Level 1 Expert
ken skalski
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
