I have a Sony KDL-40XBR7 that I have connected to my laptop. Now there is an error message that say's "unsupported signal". I also noticed others on this site with simmilar problems but with no solutions. Can you help?
  • 130 Answers
Hi
you have to download a driver from sony and load it on usb memory stick and install via the usb port on tv
Posted on Sep 29, 2010
Sony KDL-40XBR7 flickering issue
LCD sets often use two boards (some combine both into one board) that drive each side of the screen---different names for different brands like Inverters--also set here may use a backlight but usually it affects whole screen if not working.
Problem will usually get worse so maybe time to take it in now for repair and not allow it to damage parts that are good right now.
Apr 29, 2012 | Sony KDL40XBR7 40 in. LCD TV
Conecting my laptop to my tv via a vga cable coming up unsupported signal what do i do please help thank you
Reduce Display Resolution of laptop external monitor output, go to my computer > control panel > Display > Settings > Screen Resolution.
Thanks.
May 14, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Unsupported audio signal. check your audio output. cable box > hmdi > tv
double check your HDMI cable and connectors and make sure that they are properly connected. try to replace your AV & HDMI cables
Feb 02, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40EX400. Every morning I have to reboot my cable box to get my cable signal. I get the "Unsupported Signal" message and no picture if I don't. I have seen other posts about this...
All symptoms show that cable box is cause of problem, not sure that its internale circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
TV sounds good because it works fine with blu ray player that is HD signal as well.
Change cable box just to confirm it.
I hope this tv would be under warranty so ask nearest Sony service to update its firmware under warranty cover that might fix the issue.
Thanks.
Jul 05, 2010 | Televison & Video
How do I connect my laptop to a Sony Bravia model KDL-40S4100?
Two options are available to you-
1. Through VGA Cable(Same cable which goes from CPU to PC Monitor)- For Video.
Take to PC Mode from MENU -> EXTERNAL I/P -> PC.
2. Through HDMI Cable.
Take to HDMI Mode from MENU -> EXTERNAL I/P -> HDMI.
If Still No Video
CASE1- 'NO Signal' Message Comes, then toggle the laptop screen with Function Key (depending upon laptop company).
CASE-2- 'Un-Supported Signal' Message comes then adjust the resolution to 1024*768 or 800*600 or as mentioned in Manual.
Please intimate me if any other problem comes after that.
Jun 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony bravia klv-32t400a hdmi input through x-box and p.c gives error reading - unsupported signal! check device output. both are on 1080p using hdmi to hdmi cable v1.3 why no vidio, only audio
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Mar 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
Electro Med Services...
