Question about Kicker KX700.5 Car Audio Amplifier
How do you get protection light off and power light on?
  • 64 Answers
Their a reason the protection light is on, one check the ground cable, make sure the conection is good and the right gauge next check the power cable make sure theirs no nics on the wire now check the speakers conection ,it seems to me theirs something ground out. thanks
Posted on Sep 29, 2010
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Amplifier protected LED on. what to do
Take it to the repair shop. Something is blown.
Apr 26, 2015 | Music
I have a dual electronics 4 channel amp that goes into protect mode as soon as i throw power to it
unplug all the speaker from amp then power on. if you still have a protect light amp is bad and if you have no protect light continue to hook up each speaker one by one while amp is on till you get a protection light and that speaker would be the source of your problem
Jun 02, 2010 | Dual Car Audio & Video
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
May 28, 2009 | Jensen LXA300 Car Audio Amplifier
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Legacy 1470 smoke prob.
If it begins to smoke with only the B+, ground and remote connected, the power supply transistors have likely failed.
The protection light generally won't come on if the power supply is blown because the supply must be working for the protection circuit (which protects the output transistors) to engage.
The power light may be connected to the B+ side of the power supply. If that's the case, the power light will illuminate even if the amp is inoperative.
Let me know if you have any other questions.
Aug 27, 2008 | Legacy 4CH 1000W RED AMP Car Audio...
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Mac-505 amp
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Dec 19, 2007 | Car Audio & Video
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Kicker KX700.5 Car Audio Amplifier Logo
88 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
