Question about Briel Multi-Pro ES-200A Espresso Machine
My Machine leakes water
I love this coffee machine. All in all it works great! We clean it now and then and sometimes leave it on all day but it keeps giving us great coffee. The problem however is lately we have been placing a toewl in front of the machine because water seems to be leaking out of it somewhere. to me it seems somehow everything left over may not be making it to the tray orm it could be something else not sure. My wife is starting to et on my case about this so I am trying to get this fixed but cant figure out what i should do. I HAVE THE SAME PROBLEM. iT APPEARS TO BE SAT THE SWIVAL BASE. SOMETIMES AFTER REFILLING THE WATER IF I DO NOT MOVE THE MACHINE IT IS FINE.
I had the same problem with this fabulous machine.
I opened up the top, and I discovered that the problem was a small crack in the piece that transfers water too and from the heating chamber and the pump. This small junction piece is between the pump and the chamber and it also carries water back to the reservoir. It developed a small crack which resulted in water not reaching the chamber and flooding the machine. I am presently working to patch the crack and i'd be grateful for any suggestions. I have attached pictures below.Sorry for the low picture quality.
Posted on Feb 18, 2009
  • 32 Answers
If you have a Briel machine you can ask the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 18, 2008
    President:
  • 2,712 Answers
There is a rubber valve (usually spring loaded ) which is resident behind the shower screen. This may be old, or become hard and will need replacement. You will have to undo the shower screen to get to this valve. However, if your machine is under warranty, I would advise against this as it would void the warranty. Best call the manufacturer/ point of purchase in this case.
Hope that helps..
IrishDruid
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson May 24, 2008
    Found this solution elsewhere. Have a go at it first, as it is the easier to do..
    "there is a drain located in the back of the machine that drains into
    the drain tray. If this drain is clogged (like mine) when ever you
    brew, the small excess water, instead of draining as it should into the
    tray, drains into a very small reservoir that holds the slight excess
    of water that occurs with every cup. When the reservoir finally fills
    up, it pours over the lip and into the machine and all over the place
    missing the drain tray. It is messy.
    The solution is to remove the brew group, look into the back where the
    brew group inlet nozzle fits, and you will see the discharge nozzle
    leading down from the top left and into a reservoir. You cannot see the
    drain because it is behind the axle that drives the group, but you can
    feel it if you stick your finger in and down to the right. You can see
    its discharge port, down at the drain tray. Clean it, until you can run
    clear water into it and see it drain out the bottom drain port into the
    drain tray, which you should reinsert before you pour water."
    Hope that helps..
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Leaking Saeco lpus vienna machine
Keep cleaning...make sure that run off spout the leads to the tray is 100% clear. Run water through it (with a sponge for example) to make sure you get all the sludge out. Careful about what sort of coffee you use. I have had bad luck with Illy coffee unfortunately.
Apr 01, 2014 | Saeco Vienna Espresso Machine
KitchenAid Pro Line espresso machine leaking water onto counter after repeated shots
I keep hearing how this machine makes great crema but I'm about ready to toss my machine in the dump. It seems like the water comes out way too fast no matter how I work the grinds or tamp it. Can someone contact me about what might be wrong?
Dec 26, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
My keurig machine is brewing only a little water and sometimes not working at all. slow brewing time. just started. no problems yesterday
mcdevito75 here, You may need to clean the machine. water used to make coffee leaves deposits in the brewing holes and has to be cleaned out. Refer to the owners manual on cleaning.
Jun 13, 2010 | Keurig B50 Coffee Maker
Gaggia Coffee Deluxe: After I run decalcifying solution throught the machine and replace with fresh water, the pump stops working. I can hear it running, but it will not **** and push water throught he...
The desolve scale have blocked the vibrating pump. You are write sometimes it can be unstuck by itself hoever this time is seems that more scale blocked inside the pump. If you know how you can open the pump directly and clean it with a wire brush. If you find it dificult you can try decalcifying solution once more and leave it for more time inside the machine so that more calcium will be desolve and probably you will have the pump unstuck. When you try to test the machine dont leave it work continuasly for more than 2 min cause this will burn the coil of the pump.
Please remember to vote for this answer
Feb 14, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
Standby light is flashing
I had the same problem with my machine and managed to get it working again in a few easy steps. This machine is great but it can be VERY tempermental so here are a few tips:
1.The barcode reader MUST be clean or it will not read what the disc is (It is the little glass screen where you place the disk.) If it is not clean the lights will all flash.
2. The little floaty thing in the water container has to be floating in order to keep the machine running- if it won't float, shake it well to dislodge the air pocket that might be jambing it.
3. If the red stanby light won't go away, it is because the disc you are using is either damaged or leaking and it WON'T go away until you replace the disc...(you might have to do it more then once) if that doesn't work- try hitting the reset button on the back of the machine (the little black switch that has a (- and o) as well as unplugging and plugging the machine back in. Lastly, what worked for me was inserting a new disk and only partially clicking in the disk so the 'heating' light came on- leave it like that for about 10 seconds and then very slowly close the disc completely. Hope this helped!
Feb 19, 2009 | Braun Tassimo Espresso Machine/Coffee...
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Most likely your boiler gasket has a leak
here can you download all diagrams you need to figure out what is wrong with your machine
SAECO
May 23, 2008 | Saeco Vienna De Luxe Espresso Machine
Brewed coffee will not come out
Two things you point out. One is water tank leaking- where is it leaking? Is it cracked?
The other problem you point out is that coffee is not coming out but do get water- which could be that the grinder needs to be cleaned (internally) by an authorized SAECO Service Center .
Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Dec 08, 2007 | Saeco Vienna Digital Coffee Maker,...
Briel Multi-Pro ES-200A Espresso Machine Logo
275 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
