Question about Connex 3300 240-Channels Base CB Radio
Talkback can i put it on a switch - Connex 3300 240-Channels Base CB Radio
    Guru:
  • 773 Answers
You can. Just wire a switch in between the resistor, and the solder point.
Posted on Oct 07, 2010
  • Don Reiman Oct 07, 2010
    Wait, I am sorry, I didn't realize the radio you were using. There is but I do not know it for connex.
My phonelocked after putting talk back to ON CANNOT PUT IN P
try and press and hold both volume buttons should come up and say suspend talkback highlight the ok press it quickly a few time then the voice should say talkback suspended
Mar 12, 2018 | Cell Phones
How to turn off talk back setting
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
See link below
https://support.google.com/accessibility/android/answer/6007123?hl=en
Jan 16, 2017 | HOW Video Game Consoles & Games
How to get talkback turned off
Hi Michele
Feb 29, 2016 | Cell Phones
How do I put talkback into a Dx33?
it can be done but it is a long process . check out www.cbtricks.com they have the information you need about talk back . if what they have isn't what you want you may have to google it for the information you want.
Aug 27, 2015 | Radio Communications
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
No talkback
Remove D80 to achieve talkback, or put on switch. - www.killercatradio.com
Aug 11, 2010 | Superstar SS-121 120-Channels Base CB...
Want to get talkback in a cobra 29
When you key up the mic ungrounds the speaker so you don't hear anything through it, so to get talkback you're putting a 100 ohm 1, or 2 watt resistor between the switched side of the speaker and ground, now when unkeyed the mic grounds the speaker as usual, but when you key the resistor allows a bit of audio from the audio amplifier, not decoded RF, to still get through. I think the pa/ext spkr. jacks are a convenient place to connect it. You may decide to control talkback by running the circut thru a switch like brite / dim switch . Want less talkback, use more resistance, 150 ohm . Too much talkback can become feedback . I hope this helps, J
Nov 25, 2009 | Cobra 29 LTD CB Radio
Hi, I have a connex 4600 turbo and I have a problem with the talkback on/off switch wiring. Can you tell me were the white wire attaches to from the switch? Thanks
The white wire coming from the Talkback switch goes to The middle of TR30. This location is towrd the back of the radio on the right hand side by the transformer with the radio facing at you!!
Jun 06, 2009 | Magnum 257 CB Radio
I want talkback on my cobra 29ltd classic radio how do i do this myself
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
Mar 30, 2009 | Cobra 29 LTD CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at rollincbmods@yahoo.com. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
50 people viewed this question
Top Connex Radio Communications Experts
Steve
Tony
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
