When i try to open my disk tray it says locked
  • 1 more comment
  • td7272 May 26, 2008
    I don't have the instuction booklet
  • sweckk Aug 01, 2008
    tray will not open shows a lock on the display
  • unclecolin Oct 08, 2008
    I have an instruction manual but it doesnt offer any advice on this at all
I had same problem with JVC player. Found out from manual that there is child lock- activated by pressing stop + eject when unit in stand-by mode. (which I must have done accidentally) Unlocked by repeating action - in stand by mode.
Posted on Jun 27, 2008
  • Valentine Valentine May 11, 2012
    This also worked on my Magnavox MDV110 player! The CD was stuck and the door didn't open. I turned the unit off, pressed Stop + Eject together, and pressed Eject again. The tray finally and magically opened!
Mine did as well - a flashing key appeared. Not in the manual. I called; they'd never heard of a flashing key on the display. Turns out there's a "lock" button in the lower third of the remote that I must have hit by accident.
Posted on Jun 08, 2008
  • giantdoonut Nov 07, 2010
    I had to completely cut off the power. When I turned it back on it opened right up. Mine is a samsung.
  • hedon4desire Jan 22, 2012
    thank you giant, the tip worked for my samsung. all the best
Turn off dvd player(don't unpluged from power), press stop, hold and press eject button - it work
Posted on Jun 29, 2008
2 Suggested Answers
  • 10 Answers
SOURCE: disk tray will not open
replace loading belt...or if not u can clean it.
Posted on Feb 27, 2010
Tray won't open. I do have a disk in it.
If its like most disk drives, there should be a very small hole near the front door. Straighten a paper clip, and push into the hole. You should feel slight resistance - this is the lock for the tray. Pushing on the lock should cause the tray to open.
Jan 25, 2011 | Microsoft Xbox 360 Console
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
Jul 26, 2010 | Sony DVP-NS315 DVD Player
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Disk tray will not open
Feb 27, 2010 | Panasonic DMR-ES10 DVD Recorder
I bumped into my dell computer disk tray while it was open, and popped it out. When I try to put it back in, it seems to lock into place, but when I push the button to close the disk tray, it only goes in...
It sounds like you have the drive gears on the tray out of sync with the tray. Pull the tray out all the way again if you can. On the left hand side of the drive is a large gear that engages the side of the tray, turn this gear counter clockwise (the same way it turns as the tray ejects). You should be able to see a plastic slide with a rack gear on it (teeth in a straight line). Slide this part all the way to the right. Now try inserting the tray back in. Good luck.
Aug 21, 2009 | Dell Inspiron 530s Desktop Computer...
Disc tray locked
there is a small hole outside the disk-tray. it may anywhere
put a thin needle inside that when the computer is on
warning: Be sure that you stand or touch on a wooden plank for safety
Jun 08, 2008 | Panasonic SC-HT70 System
Samsung HT-DB120 DVD tray
I assume it DID work at one time. You need to take it apart and see how the tray is driven... belt or gear. If belt driven you could replace the belt.
Geno
Mar 04, 2008 | Samsung HT-DB120 System
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
Trouble with the disk tray
clean the tray, or replace the belt open the cover of your dvd
Jan 19, 2007 | Toshiba SD-3980 DVD Player
Televison & Video Logo
457 people viewed this question
Top Televison & Video Experts
Electro Med Services...
