Question about Roper Washing Machines
I need to replace the water valve, but dont know the best way to access the old valve. I have Roper Model RAS5133EQ. I have the new valve but don't know the proper way to install it. I don't know how to open the machine case and was told not to take the back off for this repair job.
  • 20 Answers
There are 2 screws on the front or back of the control panel that are angeled in remove them then remove the lid switck connector & 2 clips then remove the cabinet. watch this viedo http://www.youtube.com/watch?v=6XIsK3W_Qcg
Posted on Sep 29, 2010
Replaced a cracked fill valve but have no water flow
so buy and replace the faulty valve,,,
i dont see your actual question
dont see the issue
Mar 05, 2015 | Roper Washing Machines
I just moved into a new place and hooked up my Roper 111-07 washing machine. I have notice that no matter what temperature I select for the rinse cycle, hot water is the only thing that comes out. I only...
Hello Stephanie Wells,
Since it is the "new place" that changed...
I would FIRST look to the COLD WATER supply
to make sure cold water INDEED comes out of the
MACHINE END of the hose.
Then move on to the cold water valve...
>> Take PICTURES before disassembly.
Not terribly expensive... Pretty easy to change.
(you may get your NEW PART as differently
connected than your old (PRESS FIT couplings
are replacing the OLD threaded type...
ALERT: PRESS collar in to release tubing)
HELPFUL VIDEOS:
Check these (USA) parts suppliers to
find your specific water valve
(even available through AMAZON)...
Let price/reputation be your guide...
ALL these folks peddle the same parts (opinion)
appliancepartspros
Search Over 2 1 Million Appliance Parts
AMAZON: Roper
285805 Roper Washer Washing Machine Inlet Water Valve Replacement
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Good luck
Carnac the Magnificent
May 08, 2017 | Roper Washing Machines
Ice Maker not receiving water past the valve? at the bottom of refrigerator.
tap gently on solenoid . it is probably stuck from corrosion. if that doesnt work you will need a new one. go to any appliance parts dealer they should be able to supply you with a aftermarket replacement water valve.
May 26, 2012 | Roper Refrigerators
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
Roper top load washer model # RAX 4232Jq0 not getting any hot water. Checked the inlet valve screen and it is clean and hot wat is getting to the machine. Could it need a new valve and is this a part...
It sounds like you have already diagnosed your problem. You probably do need a new water inlet valve. The following link explains how to replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. Prices vary, so shop around. The part number you will need for model RAX4232JQ0 is: 285805 and lists for about $30. You can view an illustration of the part as item 18 under the "Controls and Rear Panel" parts listing.
If you need further assistance, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool.
May 11, 2011 | Roper RAS6233KQ Top Load Washer
I have a roper,1 year old .The water will not stop running on spin cycle or when stopped ? Have to turn the water valve off ?
First off, you say one year old. If it is one year or under, it has a one year warranty and you need to contact your nearest authorized whirlpool repair. Your problem is that the fill valve where the two hoses fasten onto needs replacing. You can go to your nearest parts house with your complete model number and they can help you get the right part. Thanks
Jan 17, 2011 | Whirlpool Washing Machines
My washer keeps filling with water in the off position at first the cold water would barley run and know it runs slow all the time in the off position it's a roper washer
Your water inlet valve has probally failed.
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available.
Apr 07, 2010 | Roper RTW4300SQ Top Load Washer
Cold wtr runs while in off position
This is caused by a bad cold water solenoid on the water inlet valve. You will need to replace the valve in order to correct the problem. The following link explains how:
This is a simple and inexpensive repair. The average cost of a new inlet valve is about $30-$35.
Replacement parts (if required) can be purchased at any of the following web sites:
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool, so these instructions do apply.
Feb 15, 2010 | Roper RTW4100SQ Top Load Washer
You can get water from door but no water going into icemaker roper
the ice maker give 120V for short time to water valve when the time come for new batch of ice. if the valve not getting it your ice make unit need to be replace.
Dec 31, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Hello. I have an old Roper oven, model no.
The ignitor draws amperage thru gas valve which opens the bimetal valve to release the gas.Round ignitor 2.75 amps. Rect. 3.5 amps.Bottom line if burner dont fire within 60 seconds of turning orange you have a weak/bad ignitor.Hope this helps.Please rate my response :)
Jun 20, 2009 | Ovens
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
