Question about Lexmark Color JetPrinter Z23 InkJet
Printer I had windows 98 reinstall and now my printer won't work . Do I need to have the disk for the printer for it to work. It says error writing to lpt 1. Please help me if you can.
I AM UNABLE TO REINSTALL MY PRINTER. WOULD YOU PLEASE BE SO KIND AND GUIDE ME ON HOW TO REINSTALL MY LEXMARK Z23.
Posted on Jun 19, 2008
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
I have bought a BTC extrenal disk drive USB 2.0 CD-RW 52x24x52x. My computer is regestering that it is in the usb port but it will not read any disks. I have an Acer travel mate 2300 laptop
A BTC CD-RW drive is compatible with Windows 95/98/NT/ME/2000/XP and it can read and write under Windows 95/98/NT/ME/2000/XP.
Under DOS, the drive can read CDs only.
The quality of CD-R/RW media varies from different brands. A CD-R/RW media with bad quality causes writing error and makes a CD-ROM drive difficult to read.
Please check if the disc has deep scratches, fingerprints, or other contaminants on the discs surface. Clean the disc if it is necessary.
1. Use the burning software which is provided by original supplier and bundled with this CD-RW drive or download the update file from internet. 2. More capacity of hard disk is needed if using hard disk as temporary buffer. 3. Place the disc correctly. 4. The blank disc needs full format first if using Packing Writing software.
Software such as; EasyCD Creator, Nero-Burning ROM, NTI CDMaker are the only supported.
Flash firmware for Windows mode: 1. Please download the appropriate driver file you need from this page. 2. Run the flash program under Windows. 3. Click on the ¡uUpgrade¡vbutton under the flash program 4. ¡uStatus Upgrading¡vis starting to flash the F/W 5. After flashing, the system will appear ¡uComplete¡IPlease restart your computer¡v, then, restart your computer to finish the flash procedure. Note: 1. BTC do not recommend you to upgrade your F/W, if the drive is working properly and does not encounter any irreclaimable problem issues. 2. BTC is not responsible for any defective reasons if the upgrading process caused the issue. Firmware for windows:V000F.exe
Dec 01, 2010 | Computers & Internet
Cannot download hp psc 750 disk software
try here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?dlc=en&lc=en&product=57769&lang=en&cc=ca&
only choose your windows and go!
Mar 06, 2010 | HP PSC 750 All-In-One InkJet Printer
XP Cannot able to print on Epson LX 300+
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
May 25, 2009 | Epson LX-300 Matrix Printer
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
I/O ERROR 1785
what type of hard drive format do you implemented (FAT, NTFS) if you formatted with NTFS. the movie magic will not recognized the format. it need to be FAT.
Oct 20, 2008 | Televison & Video
Not,able,to,run,any,programs.dynamic,link,library,failed,oleaut32.dll,cant,start.error,by,widows,explorer,c06d007eh,in,module,sens.dll
hi harold what operating system do you have?
it seems that a reinstall is probably the best , hope you have your data on a seperate partition or hard disk, and recent backups?
Apr 25, 2008 | Computers & Internet
USB PORT FRO FLASH DISKS
i hope u have downloaded the driver from the net and installed and then u r trying...
may be there is a problem with windows 98 os so hust reinstall it... just it takes 10 to 15 mins to reinstall and u will not lose any file... it will ask "do you want to keep the files" just give yes and then give a try..
if u r trying with installing the software then just download it from the net and install and then try...
after that also if ur system hangs means then just try in other pc where windows Xp is there... if it does nt works means then may be ur flash disk read and write cycle is over ...
for the flash disks there will be limited read and write cycles so...
Feb 06, 2008 | Microsoft Windows 98 for PC
Lexmark Color JetPrinter Z23 InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
