Question about Mtd 22" Yard Machine Push Mower
I Have a push lawm mower (mtd product model # 11a-439s729) serial# 1d261k81143 I have to prime before pulling the lanyard to start . I have no problem starting the engine ,the real problem is it will die down in a few seconds, the fuel line is ok .I not sure about the carburetor. Any advice or solution to the problem is greatly appreciated..
  • 3,740 Answers
I really need your engine number but I am going to guess that it is a 3.5 to 4 HP Briggs & Stratton with a black primer bulb on the side of the carb.
Try this the next start. Take a screw driver handle just a bit smaller than the primer bulb and FORCE it against the carb body trying to make a seal with the primer rubber against the carb body. You use your thumb if you can manage to depress the entire area of the center of the primer bulb agains the carb body. If it runs normally when you do this..... the Primer Bulb has a pin hole in it. (No joy..... read on)
If after doing the above you strill have the same problem remove the air cleaner and tighten all of the screws that mount the carb to the gas tank. Often over time the carb body will warp and then it starts getting air introduced into the diaphram that is between the cab and the gas tank. Tighten the screws. There are usually 5 of them. (Remember the body is plastic.... tight but don't break it) Then try another start.
If that does not work the diaphram between the carb and gas tank is probably damaged and will need replaced.
If you need parts info respond with your engine number or go to www.briggsandstratton.com and look it up for yourself using your ENGINE TYPE MODEL SERIES number found on the air shroud above the spark plug.
Thanks for choosing FixYa.
Kelly
Posted on Sep 29, 2010
Are all MTD push mowers that begin with 11A basic(ally) the same?
No, when I searched your 11A-020L-765 It brought up a lot of 11A- and some had overhead engines and some did not, had mulching and big wheels and enough that the answer is no.
Mar 25, 2016 | Mtd Garden
Cannot find any information on my mtd mower
I searched it and came up with this info, at the bottom of the of the info page was a pdf owners manual, also under specs it shows the engine as a Powermore, new one on me, Huskee 21 in 2 IN 1 140cc Push Mower CARB Compliant For Life Out Here
MTD lawn mower won't stay running.
Did you empty the carb bowl and clean out any old fuel & contaminants? This is the most effective way to determine fuel issues. It also gives you the opportunity to remove all old fuel from the fuel lines, filter, & drain the tank bone dry. You may have already introduced water from your previous efforts so take out the plug & pull the cord a few times to dry out the cylinder. Next start the first time with starter fluid since you may still have contaminants in the primer system. In the future use only non-ethanol fuel, a marine grade stabilizer such as "Sea Foam" and replace all fuel every spring. Fuel begins to varnish and break down after 1 month unless stabilizer is used. Ethanol gas absorb water from the surrounding air in about 2 months & only gets worse.
Sep 06, 2015 | Mtd Garden
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
I recently received an MTD Yard Maching 4.0 22" cut model 11a-084e352 from a friend but with no operator's manual. I need to give it a tune up. What kind of spark plug does it take? I'm...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1 that's where you can find your manual. Just put in your model number, and serial number too and your manual(s) will be accessible.
May 16, 2011 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Jun 09, 2009 | Mtd 22" Yard Machine Push Mower
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
425 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
