Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
The hinged seal feel off the door oy my Kitchen Aid refrigerator, how to I re-attach it?
  • 1122 Answers
SOURCE: kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Posted on Oct 15, 2008
SOURCE: Kitchen Aid Superba Refrigerator KSFS25FKBL01
I have the same problem, if you take off the cover at the bottom of the unit on the left side you will find 6 wires inside a plastic braid, my guess is that you will find some or all of the wires broken, this is due to poor design. they break by simply opening and closing the door. I have contacted kitchenaid and their response is more or less "tough luck". You may have to replace the entire freezer door, good luck
Posted on Mar 04, 2009
tborn6
  • 700 Answers
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
cj2176
  • 520 Answers
SOURCE: Kitchen Aide Superba 48 1997, refrigerator door remains ajar,Fix?
They actually make a guard that acts as a height shim. You do need to remove the door to install it though. Try looking at appliance411 they usually have some insight into out of the ordinary parts. Hope this helps. Good luck.
Posted on Aug 04, 2009
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
Can the doors be removed to aid access through the kitchen doors
Yes, The hinge covers should be easily removed to expose the hinges, then release the hinge from the door.
Dec 28, 2014 | Refrigerators
Freezer door
make sure there is nothing stuck in the hinge
Oct 17, 2014 | KitchenAid Kitchen-Aid Bottom Freezer 24.9...
When i close the left door the right door pops open 1.5 inches this problem has just started i have had the unit for 4.5 years
I had the exact same problem with my Kitchen Aid French door refrigerator...... I had my appliance repair man come twice and we finally found the problem........... the LOWER DOOR HINGE was broken on the inside. you can only tell when you go to remove the hinge from the inside of the door. he replaced it and it works beautifully. I read how many people have had this problem and have replaced the gasket on the door but it didn't solve the problem. that's because it's not the gasket it's the lower hinge in the actual door. good luck
Jan 21, 2011 | KitchenAid Architect KBFA25ERSS Stainless...
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen aid Supra
At the top left hinge there shuld be a cover over the hinge. Remove that cover and check to see if plug connectors are securly plugged together. Double check the right top wall of the refrigerator section and verify the model # I did not locate info on the model you posted.
supertechks
Nov 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
27 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
