Question about Refrigerators
The water engaged on its own and wouldn't stop flowing and we had to open door to stop and now it is not working at all. We turned off water at shut off. Any suggestions?
  • 20 Answers
Is it a ge
Posted on Sep 29, 2010
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Apr 21, 2012 | Refrigerators
Model D1776 Continues to Fill with Water/Drain Pump Engages After Wash Cycle Is Complete
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Oct 24, 2011 | Asko D1776 Built-in Dishwasher
I have GE refregrator (side by side) GSS22JERF, water is continuesly flowing through the water dispenser . finally I have to shut down water intlet to refregirator. what will be the issue?
You are describing a problem to be either your water valve is stuck open or you may have air in the line creating a siphon. If with the water on, if you unplug the water valve in the back, does the water stop flowing? If yes, problem is door switch, if not, its the water valve not closing. Have you recently replaced the water filter? Did you flush out the air? If not this is called a siphon effect and can cause the water dispenser to run after dispensing water.
Those are things I would look for.
Sep 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have Paloma PTG2 42PVN No water flow when I open the faucet. I turn the water heater off at the remote and then back on and I get water flow for about30 seconds and the water is warm, then the whole...
Question is not clear.
Does all water flow stop? Or does hot water flow stop?
Open following links for possible help.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Nope, found out that the water turn off valve did not completely stop water because that also needed to be replaced. torched off the faust, but couldn't solder the new one back on because of the water...
Next time turn the water off at the water meter,if possible. One trick to stop the water flow is to take a slice of bread ,and jam it into the pipe,and do your solder job the bread will disintegrate after a short time.
Aug 16, 2011 | Garden
Water and ice dispenser stopped working
Hi
Thanks for using FixYa. If both water and ice dispensers are not working then it can be an issue with the water inlet valve going bad. . To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | GE Profile PSW26P Stainless Steel Side by...
My whirlpoolconquest ice maker has stopped making ice. I have replaced the water filter, which has worked before. I have switched off the ice maker for several hours and then switched it back on, and...
Hi
Thanks for using FixYa. To start with check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve. If still the issue is not resolved then remove the ice bin, Remove the wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Refrigerators
Water coming out bottom of door on wash cycle.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
Jun 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
