Question about GE JGBC20 Gas Kitchen Range
GE XL 44 Kitchen Range
My oven stopped working. I have been having problems with the stove igniting for a while and now the oven has stopped heating.
  • Ted Oct 27, 2008
    I have had the igniter/glow bar replaced 2 other times before by a repairman and I am planning on doing this myself. Where can I find the part I need?
    President:
  • 1,314 Answers
Replace the ignighter bar in the lower oven pull the racks out remove the two screws in the oven bottom pemove the panel under that remove the metel flame spredder the ignighter is at the back of the burner bar get your model number and go to appliance parts store for a new one and follow inst even if it glowes doesnt mean its good it should light the oven whithen 30 seconds
Posted on May 24, 2008
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
GENE
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My ge xl44 gas range ..all of a sudden the oven does not work...eveything else does... do i need someone to come out? HELP...
Probably just a weak ignitor. Fairly common on these. If you can change a spark lug you can change an ignitor.. These get weak and dim. if yours comes on but is dim orange it is weak and not allowing the bi-metal to open. If yall bump the stove and the oven comes on that is another sign of a worn out ignitor:
GE XL-44 stove service manual
How it works: Silicone carbide ignition
A tip by TheMobilian
Apr 21, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 gas kitchen range. Oven does not work
Sounds like the switch module is defective.  You might get lucky if you power down the stove for half an hour and then reapply power.   Sometimes they reset.  If you, enjoy.  If not, you will need that module.
Nov 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBC20 Gas Kitchen Range Logo
356 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
