Water continues to flow into bowl and overflows on to the floor
  • 20 Answers
If it overflows while not in use it will be the water valve. If it overflows while in use it could be the water valve or pressure switch or pressure hose kinked or cloged or pressure chamber cloged need model number for more info
Posted on Sep 29, 2010
Not shutting off completely when flushing
You're to replace shutting valve.
Jan 25, 2018 | Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Have a fluid master valve--I believe it is a 883B--fills the toilet and appears to shut off but very slowly keeps filling. Never actually shuts off completely..Please Help!!
there are only 2 possibilities; 1 the tank seal is leaking into the bowl and the input valve runs to replace the water lost, or 2, the water inlet valve does not shut off totally and the water continues to flow into the bowl via the overflow tube in the tank.
If the water is running into the overflow tube, adjust / replace the input valve, if the water is not going into the overflow valve, clean / replace the flapper valve at the bottom of the tank.
Please let me know how you make out.
Aug 25, 2011 | Home
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
Please tell me how to get more water in my toilet bowl..not the tank..the bowl please..thankyou. It is a Jacuzzi Era Elongated bowl.
The water level in the bowl is determined by the built in trap in the back of the bowl. Water is allowed to enter the toilet and it then "over flows" the p trap in the back when flushed. Once it's flowing, it syphons the water out of the bowl. While the tank is re-filling, a small portion of water should be running down the overflow from the small hose clamped onto the overflow This rinses the inside of the bowl, as well as helps-refill the bowl. Be sure that hose is directed inside the overflow tube. To see what the max water level in the bowl can be, add some water from a cup or glass. Once it's full you can keep adding and it won't get any higher. This will be the max level you can expect.
Jul 07, 2010 | Jacuzzi BK37959 White Era?? Two-Piece...
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
336 people viewed this question
Top Washing Machines Experts
