Question about Whirlpool GBD277PD Electric Double Oven
Oven gives code E6 F2 on panel
Our electric double oven, which is 4 yrs old (model #GBD277PD509) stopped working last Saturday (it was not being used when it went down) and, every 6-8 hours or so, displays a code of E6 F2. (If the code isn't displayed, the panel is blank.) Do you have any ideas of what has happened and how do we fix it? John - May 24, 2008
I too have the same problem (Fault Code F2 - Error Code E6) with an oven that is approximately 5 years old (Model No. GBD277PDB6). It was not in use when the code was displayed in fact it has hardl'y been used since it was installed (Maybe 20-30 times) and has never had its "Self Cleaning Cycle" run. This is the second problem I have experienced with this unit. The first time, approximately 2 years ago, the display would go blank periodically. I arranged a service call and the technician did not seem to have an answer other than the connections between the keypad and ribbon connector might be loose. He fiddled around with them and fixed the problem. This time, although the symptom was different, I decided to try the same remedy. I dis-assembled the oven front (As I had seen the technician do previously) and applied finger pressure to the connectors to seat the contacts. This seems to have worked (2 hours so far). However, one question I am left with is the reference to a "CANCEL" button on Page 2 of the Tech Sheet I found inside the control plenum behind the keypad. In the "Recommended Repair Procedure" for F2-E6 it states:
  1. Check keypad connector for firm connection
  2. Press CANCEL. If error code returns after 60 sec., replace keypad.
  3. Replace Control.
I could not find a CANCEL button. It is not on the outer surface of the keypad or on the PC card on the inside as far as I could determine. Also I could not locate it on the "Wire Harness Schematic" or "Oven Strip Circuits" that are shown on the service document mentioned previously.
I would appreciate any help that could be given regarding this issue.
  • 3,037 Answers
This button would only be on the outer control panel. Whatever button you press to stop the timer would be considered the cancel. I am a little confused, were you able to stop this error now or is it still coming up with this error? If I may suggest, perhaps you may want to rewire the loose connections. Please let me know what other questions you may have and what situation with this problem is and I would be more than happy to help you with anything else you may need.
Posted on May 24, 2008
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    President:
  • 1,314 Answers
I have you a tech sheet for you accept this soultion and e mail me at b4829@yahoo.com so i can send it to you just reference code f2 e6
  • robert samples May 24, 2008
    another thing you can do is to pull the ribbion and take a pencil eraser and clean the end of the ribbion with a clean pencial eraser also there is a black plasitc peice where the ribbion pull it up before inserting or removing the ribbion it looks it in place be gentle when cleaning the ribbion just till the bars on the ribbion are shiny its just a bad or corred connector
    use the oven off button for which ever oven is displaying
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
I have a whirlpool oven rbs305 and the pannel shuts down and a code comes up E6 and F2 What can be done Thanks
F2 and e6 in combination indicate a cancel key open condition. What this means in layman's terms is that the key-panel Has a problem. If it was just recently cleaned with a wet cleaner, you can try drying the keypad off or even CAREFULLY warming it up with a hair dryer. Don't get it too hot so that you melt anything.
If this does not work, you will need to replace the key panel on the oven.
You can do this repair yourself and should you decide to, please just comment back with the full model number off the tag on the oven and I will give you step by step instructions on how to do it.
Good luck!!
Aug 14, 2010 | Whirlpool RBD305PD Electric Double Oven
F2 error code
F2 E6 says this:
1. Check keypad connector for firm connection.
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Dec 10, 2007 | Whirlpool GBD277PD Electric Double Oven
Whirlpool GBD277PD Electric Double Oven Logo
190 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
