Question about Fun Rise Tonka Mighty Motorized Fire Truck
Hi, I have a tonka mighty fire truck with lifting and rotating ladder, siren ( and other sounds with the push of the extinguisher ) and flashing red lights with headlights and even a dome light. My son has enjoyed it...but now for the second time, it has stopped functioning. And he hasn't been rough with it at all. When I put new batteries in the last time (after only a few days of putting new ones in) it still did not work but then did...(it was not the batteries as I put them in a radio which worked when I did). So something I did must have accidentally made it work. I cannot figure out how the " reset" switch works...or if it has any purpose at all. Thanks for any advice... Chris Thanks for any advice.
  • Amanda Renfroe Nov 09, 2016
    Any chance you figured out how to reset the Tonka fire truck?
2 Suggested Answers
SOURCE: lost Tonka part
I can't tell you how to get a replacement part (Funrise was SUPREMELY unhelpful for me, too), but we devised a solution for our broken truck.....cut a black hair elastic and thread it through the two holes of the part that would hold the fork. Tie a knot so that it sits inside the little cavity inside that part. Your kiddo can then attach the garbage can to the lifting mechanism by using the elastic--works almost as well as the fork. Hope this helps!
Posted on Dec 03, 2009
Anyone able to fix the boom ladder on the Tonka Fire Truck?
may be a toy hospital
really it is a toy and if it is necessary , get a new unit for the child
Dec 06, 2017 | The Toys
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How is fire extinguisher used
Pull the safety catch, aim at the bottom of the fire (not the top of the flame), and compress the trigger.
Jan 31, 2015 | Cars & Trucks
I have a 1988 New Bright Remote controlled Fire Truck. It has lights,siren,ladder that goes up,down,extends,retracts, and rotates and the truck goes forward,reverse,left,and right. I cleaned it up using a...
Only a suggestion but if the ladder up/down mechanism is a friction drive through rubber wheels then perhaps they are damp and sliding against each other. Time and warm air around the engine will cure this if that is what it is.
Jan 02, 2014 | Toys
I need a clamshell bucket for a Tonka Mighty Crane 758
Only thing I can offer is a link to a current eBay listing for the whole thing.
http://cgi.ebay.com/Vintage-Steell-TONKA-Mighty-758-Large-CRANE-Working-WoW-/300573398306
The only other thing I can offer is a link to Hasbro's Parts Order form:
http://www.hasbro.com/customer-service/orderform.cfm?sku=91046
And you can always call them to see if they can provide the part number even if they don't have tthe part.
http://www.hasbro.com/customer-service/phone-directory.cfm
Good luck :)
Dec 26, 2011 | Hasbro Tonka Toughest Mighty Crane
What is the firing order for the 1993 Mitsubishi Mighty Max? and which is the #1 on the cap and which one is the #1 of the sparl plugs?
I have a book. You can e-mail me at demajohn@juno.com though I'm not gonna gaurantee that I understand what I will read.
Firing order for mitsubishi pickups and montero 1983-1995
For 2.0Land 2.4L engines / Firing order: 1-3-4-2 Fig. 11 / Distrubutor rotation: Clockwise / Fig. 11 shows 4-2 on top and 3-1 below them / sparkplugs are arranged as follows from firewall to front of engine (e.i. left to right) 1-2-3-4 / (e.i. 4-2
3-1)
For 2.6L Firing order is 1-3-4-2 Fig. 12 / Distributor rotation: Clockwise / 1-3 on top 2-4 below
1-3
2-4
Fig. 15 / 3.5L DOHC engine / /Firing order: 1-2-3-4-5-6 / Distributor rotation: Distributorless
Front
2-1
4-3
6-5
Rear
hope this helps
Sep 07, 2011 | 1993 Mitsubishi Mighty Max
I have a green and red tonka ricochet Rc car and the battery is fully charged and the light is on, but it won't receive commands from the controller on any channel. What is wrong?
Hi " try to check the controller's battery condition. Maybe it is too week now and not enough to send infrared signal..
, then also try to replace new battery for confirmation...just follow the correct orientation of the battery on the socket..
if the controllers is okay..then check the reciever circuit on the vehicle...try to check if there is a open connection ...like lifted wires...
Good luck"
Mar 18, 2011 | Hasbro Tonka Ricochet 4 x 4 Radio Control...
What's the firing order for a 1990 Mitsubishi Mighty Max (4.banger)?
1990 Mitsubishi Truck Mighty Max 2WD 2.4L FI 4cyl
The Firing Order mitsutrk01:
Firing order 1-3-4-2 --------- front | | of | 1 2 3 4 | Distributor rotates clockwise vehicle | | ---------
1990 Mitsubishi Truck Mighty Max 4WD 3.0L FI 6cyl
The Firing Order mitsutrk04:
Firing order 1-2-3-4-5-6 ------- front | 1 3 5 | of | | distributor rotates counter vehicle | 2 4 6 | clockwise -------
Hope help with this (remember rated this help).
Mar 12, 2010 | 1989 Mitsubishi Mighty Max
Lost Tonka part
Jan 05, 2009 | Fun Rise Tonka Mighty Motorized Side...
Fun Rise Tonka Mighty Motorized Fire Truck Logo
468 people viewed this question
Top Fun Rise Toys Experts
Tom Chichester
ray gallant
Are you a Fun Rise Toy Expert? Answer questions, earn points and help others
