Question about Whirlpool Dryers
I have a whirlpool dryer. The gas lights up, it feels hot when you touch the back of the dryer, but the clothes don't dry. Its like the heat can't get into the drum. We checked the lint trap and the vent to the outdoors, nothing is clogged. Any suggestions
  • 20 Answers
Is there air blowing out the back if so disconect the vent & try for 1 cycle to test
Posted on Sep 29, 2010
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
My Whirlpool LGB6300 heats up but never comes back on as if the limit switch kicks on and doesn't allow it to remain hot.
Feel the coils on the gas valve. If they feel really hot to the touch then the coils are opening internally. They will cool off and work some more. Replace them.
Sep 22, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
NO HEAT
its either the heating element or the limit switches both of which you can install yourself
Feb 05, 2009 | Whirlpool LER5636P Electric Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Dryer not drying
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Jun 26, 2008 | Whirlpool GGW9200L Gas Dryer
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
