Question about GE GSS22JFMWW Side by Side Refrigerator
Doesn't sound like anything is running. Is compressor shot? Unplugged the unit for a couple minutes and plugged back in, but nothing seems to be running. All the lights work , but no blower, no compressor sounds at all. There is frost on the inside back of the freezer unit. A defrost timer was replaced last summer. any ideas? new Compressor? new Relay????? thanks
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
Have a KitchenAid Superba side by side with ice maker. (Don't know year or model number, came with the house we bought two years ago.) We took off the back panel to vaccuum coils and wipe out drip pan...
It sounds like the compressor is not running.
The compressor is the black metal dome shapped component in the back, it is about the size of a bowling ball.
- With the refrigerator unplugged take the back panel off. Find the wires that go into the compressor and follow them back, it is most likely that one came loose while cleaning. If you need help in locating where they should plug in I can help with that.
- If all the wires are connected then put the panel on and listen closely to the compressor area while plugging the refrigerator back in. You should here it start, a hum that gets a bit louder. If you do not hear this listen closely for a couple of minutes for a single 'click'. If you hear the click then you either have a wire off or the start device is in need of being replaced. This is a fairly easy repair.
If the compressor runs and there is no click and no cooling then the sealed system has been most likely damaged and the repair is a major one. This is highly unlikely with a general cleaning.
Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
No Cooling
hi there,
sounds like you may have a compressor problem. most compressors have a longer warranty on them, so i would recommend that you contact an authorized service center and have them come and take a look at it.
thanks
Sep 30, 2008 | KitchenAid KSRG25FK Side by Side...
HotPoint model HSS25GFTBB fridge warm freezer cold?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 07, 2008 | Hotpoint HSS25GFP Side by Side...
Compressor problem?
The buzzing is your compressor trying to start. It is going off on internal overload caused by heating up of the motor windings.If you have an amp meter you could check the amp draw of the comp against the locked rotor amps listed on the tag You could try to have someone test your run capacitor, which looks like a can. Could be round or oval with wires coming off it. Or try a hard start capacitor and relay to bust it loose if compressor rotor is stuck. If that doesn't do it the comp is bad.
Jun 10, 2008 | Ruud UBHC Air Conditioner
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
I think you hit it right on the head. The start device is likely bad and trys to start the compressor (but can't) and it then overheats. If this type has a small white box on the left side of the compressor, take it off and shake it to see if it makes noise and debris falls out. That's the culprit. One more thing though, if your compressor has a decal with a little blue indian head drawing on it the compressor is also dead, otherwise you can just change the start device out and you should be good to go! There's a kit that replaces that type start device, comes with a new start device and overload along with the proper jumpers, etc. and it's REAL easy to install by yourself.
Jan 04, 2007 | Kenmore 74252 / 74254 / 74259 Top Freezer...
GE GSS22JFMWW Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
