Question about Maytag Dishwashers
Hello, I have a Maytag Stainless Steel MDBH975AWS dish washer. After water fill, it is very noisy almost like a grinding sound. Is there a common problem? Is there an exploded parts view somewhere so I can disassemble the grinder portion to see if there is a loose part?
    Problem Solver:
  • 3 Answers
Impeller is jammed onto shaft ,remove motor with 1 bolt ,remove impeller by putting a plastic pen in bottom of motor turn impeller counterclockwise inspect for clearance or obstruction.either replace impeller or do like I did and put a spacer,poor design on keeper circlip caused my problem.I got my spacer from a scooter wheel between the bearings & cut off enough plastic on the impeller shaft for clearance,always good to have a spare scooter wheel laying around!!!!!!
Posted on Sep 29, 2010
Dishwasher MDB6769AWS1 has started making noise just after it fills and starts to wash
There are several moving parts: The motor, pump, valves and actuators, and the rotating sprayers. Is your door seal still okay? If it's not sealing at the top it could sound louder yet not leak water. Or the motor and/or pump shafts are wearing out and becoming noisy. Keep an eye open for leaks, as this is what will happen if the pump becomes defective.
May 06, 2012 | Maytag MDB6769AWS Stainless Steel Builtin...
We just bought a house with this dishwasher in it. It was not used for a year. When we have used it, it leaves a white powder all over the dishes and it doesn't clean the dishes. Do you have any...
There are several possibilities..
1. rinse aid reservoir is empty
2. water is hard and the setting for water softener needs to be readjusted
3. there is no salt in the hard water reservoir
4. incoming hot water temperature is not adequate
Refer to user manual at this site if you do not have one.
Hope this will help with solving the problem.
Jun 26, 2011 | Maytag MDBH975AWS Stainless Steel...
It is just not cleaning the dishes. Runs - OK
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Bought a new dish waher wile un packig it , it had some water inside is this normal
yes,it is normal,they need to test run it and leave water in it so the pump doesn't dry out if it sits in a warehouse
Mar 04, 2011 | Maytag MDBH975AWS Stainless Steel...
Aluminum pans come out stained with a dark residue.
The aluminium reacts with the solution being used. Change the detergent making sure it can be used with aluminium.
Oct 09, 2010 | Maytag MDBH975AWS Stainless Steel...
Dish washer will not fill
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 04, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Is there a product on the market that I can use to clean the inside of my Maytag dishwasher? We have very had water and there seems to be a hard crusty film build up inside. The dishes are not as clean aas...
Hello
I have used Vinegar myself.
just placed a large cup full in the top rack and ran it through with no dishes in the dish washer.
and once the dishwasher was clean we used a small amount of vinegar to clean the stainless steel bowls and silverware and glass.
I have also used this product:
http://www.reliableparts.com/product/Glisten-Dishwasher-Cleaner-1476390/Dishwasher-Accessories-461418
and it also worked..... although there are restrictions ( no stainless steel dishwasher tubs ).
I found this site for you:
http://www.mrscleanusa.com/tips/clean-dishwasher.html
I found this product for you as a bonus although I have no personal experience with it
http://www.smallwonder.info/?gclid=COyUycvLgaACFQwNDQodKm_Zjw
Feb 20, 2010 | Maytag Dishwashers
No water spraying in washer, and no error code
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Jun 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
132 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
