Question about Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI
Dayton model 5z022c\r\ns/n 25613 .0794. Pumps & Sprays fine Fuel is Full Yet no firing of the gasses, = NO HOT WATER !
Where can I get a manual for model 0078551
I was able to locate a PDF file for the DAYTON Convertible Jet Pumps and Systems/Operating Instructions & Parts Manual...I located it here: http://www.grainger.com/ec/pdf/Dayton-Convertible-Jet-Pumps-and-Systems-OIPM.pdf
Hope this is what you were looking for?!
Jan 07, 2016 | Utilitech 1-HP Convertible Jet Pump...
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
Cannot find the correct Dayton & Master Igniters
I finally found a sight. Deals & Bob's 4890 High Country Rd. Cherokee, IA 51012 Fax: 712-225-3727
Http://www.bealsmotor.com/105553_burner.html
For Model 3E218E = Part number PP200 $41.90 plus shipping and handlign
Dec 11, 2009 | Dayton E50 Heater
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Dayton 150,000 btu that won't stay lit
see if there is a pressues switch on the heater one of the tubes could be blocked,
Feb 16, 2008 | Dayton 511 Utility Heater
Northstar Electric Wet Steam & Hot Water Pressure Washer 1700 PSI Logo
123 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
