Question about Health & Beauty
My boyfriend wants me to give him a tapered , short haircut? show me.
  • Health & Beauty Master
  • 1,623 Answers
You will find an instructional video at shaveroutlet.com. Click on link below and scroll down for video
http://shaveroutlet.com/grooming/hair-clippers-and-trimmers/wahl-color-pro-20pc-color-coded-haircutting-kit.html
If this video does not suit your particular need, shaveroutlet.com offers similar videos on some of the other hair clippers that they offer
Posted on Sep 29, 2010
Cant youtube videos play
Your computer may be too slow.
Dec 22, 2017 | Computers & Internet
Why does the dogs haircuts are so expensive?
When your dog gets a haircut he actually gets two haircuts, minimum of two baths, his toenails cut, and his ears cleaned and plucked. It is a much more difficult job than a normal person haircut it takes much more time.
Aug 15, 2012 | Pets - Others
How long will it take to cut my dogs hair?
An average small dog haircut takes around an hour and a half approximately. Larger dogs will take a bit longer if you want to ensure a proper haircut.
MasterCraft 8 inch drill press (Model 55-5915-4). Problem: the whole chuck unit is attached to a post that spins and in turn spins the chuck. While trying to drill into a piece of stone the whole chuck...
Most drill press chucks are attached via a tapered post on the back end of the chuck. This is a short post about 3/4 inch in diameter and 3/4 inch tall. This short tapered post (the taper is very slight) fits into a tapered hole. That hole is often in the end of a second a tapered shaft (usually call a taper, R8 is a common designation). That shaft is about 6 or 8 inches long and fits into another hole, much deeper of course. It is this longer taper that is meant to be disassembled routinely for inserting different tools. The short one is not meant to be routinely separated. I'm not sure which of these is giving you trouble, but in either case the key thing is that the mating surfaces be clean. The means of attachment is simply by pressing them together. If it is the short post that has come apart, clean both surfaces carefully with a clean rag - you don't want any dust or dirt at all. Open the jaws of the drill chuck all of the way so that the three jaws are retracted inside the chuck. Place the chuck on the table with table raised up enough that you can pull the drill press handle down slowly but forcefully to fully seat this taper. On the other hand, if it is the long taper that has come apart, this taper is not so slight and it meant to be jammed together by hand. Make sure the mating surfaces are clean, align the tang (that's the top end of the taper that looks like a giant screwdriver blade) is aligned with where it will fit all of the way in, then just give it a quick jam into place by lifting it into place quite briskly. By the way, while clean these tapered surfaces look carefully for any nicks or bumps- you will have to remove these with a small file. It's ok to have a small flat spot on the tapered post or shaft, just keep it very small. Good luck, I hope you found this helpful. Al K
Aug 04, 2011 | Garden
The morse taper drops out of my Jet drill press[JKP-17MF]. I tried cleaning with acetone and deburing with 600 sand paper. Nothing works. Any suggestion woould be appreciated.
Clean the tapper and then either use 'blueing' or a dark felt pen and cover the taper lightly with ink.
After attempting to seat the taper a couple times examine the taper and the hole. This will show you if the fit is clean and even or not.
If there are any really bad spots they should be visible.
If there are high spots on the taper use a stone to remove them and then repeat the procedure.
If there are high spots in the hole either stone them. Or wrap some 600 wet or dry paper around the taper and use this to polish the hole.
Again repeat the procedure till you get the taper to seat properly.
If the ink doesn't show any marks then the taper is not getting far enough in to the hole. In this case you'll will have to look carefully for the fault.
Hope that helps.
Jul 03, 2011 | Jet 354166 JDP15MF 15in Floor Mount Drill...
Chuck falls out of drill press
There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
Jan 07, 2010 | Drills
Photoshop cs
please complete ur question ...
Sep 22, 2007 | Adobe Photoshop CS2 for PC
Girls haircuting
Hi There, Use the Smudge Tool in erasing Hair And adding some. An Alternative technique can be read here >>> http://mediadesigner.digitalmedianet.com/articles/viewarticle.jsp?id=19756
Sep 15, 2007 | Adobe Photoshop CS2 for PC
Health & Beauty Logo
185 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
