Question about Samsung AS18A6RB Air Conditioner
Can we wash the filters - Samsung AS18A6RB Air Conditioner
  • 144 Answers
Yes they say to put warm soapy water in bathtub soak for 5 min then rinse good
Posted on Sep 29, 2010
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Can I reuse the filters of air purifiers?
Yes, you use these filters repeatedly by cleaning and maintaining it properly. If you are cleaning it for the first time then it is recommended that you must take the advice of an expert.
Oct 01, 2014 | Filter Queen Air Purifiers
How do I open Dyson to wash filter
e0d63694-d08c-4149-81f2-c3ebd4fcc49c.jpgPress the release button upwards. Take filter out of casing. Throw filter in washing machine. hghaa finished working take filter and filter casing out. Put back filter into casing then put back as per picture.
Jun 13, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
Filters
Step by step filter washing instructions can be found in the support section of our website.
Please visit http://support.dyson.co.uk/support/dc05/dc05-standard/how-to-use-your-dyson-vacuum/wash-the-filter/filter-washing-video to learn how to wash your filter and for more information on maintaining your DC05.
If you need further assistance please call our Helpline free at 0800 298 0298.
Best wishes,
Jessica
Feb 16, 2012 | Dyson DC05 Cylinder Bagless Canister...
I was just wondering where the filter was so i could clean it out
Most washing machines have a pump filter to protect the pump from obstructions such as coins. The pump filter should be at the front of the washing machine at the bottom left or right. It should be obvious (a square or round flap) but sometimes the filter is hidden behind the front kickstrip panel. A good washing machine filter should have retractable pipe at the side so that you can drain the water into a bowl.
The best way to find out if your washing machine has a pump filter is to read the instruction book. However, you can carefully remove the kickstrip at the front of the washing machine (if fitted) to see if there is a hidden filter. Be careful because they are often flimsy and brittle and can break easily. The kickstrip usually clips into place with about 3 tabs but as I say, they are sometimes easily broken. I usually place a small flat-bladed screwdriver between the top of the kickstrip and the casing and then gently lever downwards whilst pulling forward.
Examples of washing machines that sometimes have a hidden filter are Indesit, Candy and Hoover. Most washing machines do not hide the pump filter. Hotpoint and Creda often have a pump filter hidden in the sump hose (leading to the pump from the tub), which is not meant to be customer accessible. This is a stupid place to put a pump filter because when it gets blocked, most people are forced to call out an engineer.
Taking the pump filter out
The filter should unscrew anti-clockwise. Some unscrew until they come out and some just unscrew a quarter of a turn or so and allow the filter to be pulled out. Make sure you have at least one large towel to catch water and don't take it out at all if the washing machine still has water in the drum (see next paragraph if it has).
Jun 29, 2011 | Washing Machines
The filter gives red light.Does this mean the filter must be washed or changed. How should it be washed, what does ´´washable´´ mean here?
Red light normally denoted filter is blocked. If it is a washable filter then wash it. If it liiks like a paper type filter, replace it. Washing it will make it clog up even more.
May 28, 2010 | Electrolux Oxygen Z5540 Pet Lover Vacuum
How do I remove the filter to wash it?
Hi There,
Here's a step by step guide on how to clean the filter on your Dyson DC07.
Turn power off and unplug the machine.
unplug_us.gif Step 1
  • Press the release button and remove the filter housing from the machine.*
remove_filter_house.gif *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
Step 2
  • Remove the filter from the housing. (Only the blue foam, yellow cage and white cloth should be washed.)
Step 3
  • Wash in cold water only. Please do not use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
  • Repeat the steps shown below until the water runs clear.
wash_filter.gif The filter should be washed at least once every 6 months.
  • Leave to dry in a warm place for 12 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame .
  • Ensure the filter is completely dry before replacing in the machine.
It is VERY important to make sure your filter is 100% completely dry before reinstalling it into the vacuum cleaner. Running the machine with a damp filter can cause permanent damage to your motor, or cyclone assembly.
What some people do is purchase an extra washable filter, this way they can easily swap filters when they need to be washed, preventing any wait time while the filter drys. Also after a few washing you'll notice the filter starting to deteriorate, sooner or later you'll want to replace the filter. Here's a link to the filter on our site if you'd like to get an extra one.
Dyson DC07 Replacement Filter Part No. 904979
I hope this helped you and answered your question. If this was able to answer you question, please be so kind and rate my repair helpful, or leave feedback for me. If you still have some questions, please feel free to use the comment field on the repair page, and I'll be more then happy to answer any follow up questions that you may have.
Thanks very much,
Chris Jones
GoVacuum.com
May 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Filter
most washing machines don't have a filter now , however read the owners manual to make sure if it has a filter
Jun 23, 2008 | Washing Machines
Samsung AS18A6RB Air Conditioner Logo
27 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
