Cars & Trucks Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Has no spark. replace the control module and still no spark
magoly auto
Level 2:
Sergeant:
  • Oldsmobile Expert 303 Answers
  • Posted on Sep 29, 2010
magoly auto
Oldsmobile Expert
Level 2:
Sergeant:
Answers
303
Questions
Helped
158252
Points
873
First check for power at distribuitor terminal if pwr replace ing coil, if no power check ing switch, also a common problem is some one accidentally cause a spark or short one of the fuse links by the starter may be open check them all.
2005 Prowler runs good for about 20 minutes then back fires and dies, changed spark plug, replaced coil drained gas tank and replaced feul pump, any suggestions?
problem component in the ignition control module overheating and switching the module off
the backfire is an in appropriate spark time from a problem control module
2answers
Location of the esc module on a 1994 gmc k1500 suburban & where is the wire to disconnect the esc locaticed
ESC module is for electronic spark control and is located on engine block near ignition coil . it's to control spark advance for timing.
hope it helps
Electronic spark control module
Hi, Spark is controlled by the computer. Where and when(timing). You can not change that. Each cylinder has 1 coil and spark plug. That module is built in to the computer. There are sensors around the engine that send info to the computer. Air, spark, timing, and fuel. When these things work properly the engine will run.
What does acam or crankshaft sensor do
  • The crankshaft position sensor identifies position of the crankshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM)
  • When not replaced, vehicle could experience no- or hard start, long crank time, misfire, lack of power, excessive hydrocarbons in oil, spark plug fouling, catalytic converter failure, poor fuel economy, CEL/MIL illumination or intermittent shutdown.
  • The camshaft position sensor identifies position of the camshaft to the ignition control module (ICM), engine control module (ECM) or powertrain control module (PCM)
  • 0helpful
    Where is the ignition module. Can I get to it from under the hood? Should I replace the Crank module when I replace the ignition module?
    Hi.
    The ICM is located under the hood, next to the coil pack and spark plug wires. Here the part: Pontiac Grand Am Ignition Control Module (ICM).
    If you ar having distribution problem and misfire check also the crankshaft position sensor. It signal is used to control coils and sparks.
    Its a 91 jeep cherokee 4.0 it turns over but will not start there is no spark. I have replaced the coil but still nothing
    No spark usually is caused by coil (which you already replaced), ignition control module, or pickup coil inside the distributor. The coil and the control module are the most common. The control module is located just outside the distributor, you may be able to take it off and have it tested at the dealer. The pickup coil is inside the distributor, unfortunetly there's no way to test them. Also check plugs and wires if they haven't been replaced in awhile.
    1helpful
    2answers
    94 toyota tercel with no spark
    Does it got a distribiter or does is it have a coil pack.I'm thinking an distribiter with 4 spark plug tirminals,I would look into the Ignition Control Module if it has one.I looked at a parts listing for the car and it shows it has one but looked at a Typical Ignition System Schematic and it doesn't show the igniton control module in there.But i would think it is needed to control the spark.I would look into it and see if there is one,if there is i would test it that would be my guess of what's causing no spark.I got a pic of the ignition control module and theTypical Ignition System Schematic for you.
    Hope it helps
    6h1281.jpgIgnition Control Module
    graphic.aspx?mod=reptiff&module_id=1&session_id=%7b5c99313e-132f-495e-97aa-54ddd1158904%7d&image_guid=94i44402&print_bw=0&
    Top Oldsmobile Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    john h
    Are you an Oldsmobile Expert? Answer questions, earn points and help others
