Question about Black & Decker Garden
Hi- I have a Simoniz S1600 pressure washer. Usually when I start it, the motor kicks in to build up pressure. Now it won't kick in no matter what I do. A small stream of water will come out but there is no pressure. There are no reset buttons on the exterior of the machine. Thanks so much.
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
  • 202 Answers
SOURCE: NO PRESSURE
check the coupling or the belt between the engine and pump. unsure which this washer uses. the pump may also have failed, usually it is the coupling or belt broken or slipping
Posted on Jul 09, 2009
  • 174 Answers
SOURCE: One day it was working fine the next day
It could be the thermal switch in the motor but that cannot be reset. If you used it with an extension cord, this has blown the thermal reset in the motor. You now have a blue boar anchor. If you haven't used an extension cord then it is probably the bypass valve switch. When you use your washer, then let the trigger shut off, this valve shuts off the motor. When you open the machine, you can tell where this valve is because it somehow has a small switch mechanism attached to it.This valve needs to be pulled out and greased with a good waterproof grease. If you can tell me the serial number, or e-mail it to me at firehead@rogers.com, I may be able to get you a schematic.
Posted on Aug 12, 2009
  • 174 Answers
SOURCE: S1600 Simoniz gun - I took it apart and I have a
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Testimonial: "Thanks - a little frustrating thinking there must be a simple fix - buying a new gun that will also breakdown - that's where they get you. "
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
Comressor won't kick on by itself
There should be a pressure relief valve for the discharge line of the compressor. It could be under the cover of the pressure switch. With hi pressure trapped on the piston, the motor won't start.
Dec 13, 2013 | Air Tools & Compressors
Motor turns over but seems to be a lot of pressure on it . it kicks back hard
Make sure you are holding the trigger and water is spraying while you are trying to start it, otherwise pressure will build up in the pump and it will kick back.
Jun 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
One day it was working fine the next day nothing.My Simoniz S1600 completely dead. Is there a thermal switch or fuse in it?
Aug 11, 2009 | General Garden
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
Aug 11, 2009 | Karcher Garden
NO PRESSURE
Jul 09, 2009 | Briggs & Stratton Garden
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Garden Logo
167 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
