Question about Mitsubishi WS-65611 65" Rear Projection Television
My Mitsubishi WS-65611 will not turn on
My tv worked fine yesterday.  This morning I went to turn it on and it won't.  I am not able to get a green light either.  I made sure it is plugged in and other devices work in the outlet.  Any ideas on what is wrong?  What will it cost to get it fixed?
  • 1 more comment
  • nn80659 Jan 29, 2009
    i have the same problem as of this weekend Jan 25, 2009. did you get any suggestions?
  • 2sassy Apr 10, 2009
    I have the same problem. There was a storm a two days prior. The night worked one night and the next morning it wouldn't turn on by remote or manually.
  • cissysandlin May 09, 2009
    Can anyone tell me how to fix this problem. I miss my TV
    Scholar:
  • 62 Answers
When you turn it on, can you see any signs of distortion in the picture? When I turned on my ws-65611, it would come on for less than a second and turn right back off.
I did the diagnostic test by holding down, I think, menu and device for 5 seconds and got error code 23. But when it was on, I could get a glimpse of the static screen (snow) and could see convergence issues. What I saw made me think I would need to replace the IC (stk393-110). I replaced it and that fixed my problem. I had to do a little manual convergence, but not a whole lot. When I unsoldered the IC, 2 of the middle pins fell off without any applied force. Hope this helps someone else.
Posted on Jun 03, 2009
Comes on and goes right back off, no pic or sound
Posted on Apr 06, 2009
SOURCE:
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Mistsubishi HDTV 1080 Model WS-65611
hey there! good thing you posdt back. i dunno what happend earlier but that wont stop us would it. haha
anyway right,
have you tried changing your remote? it may sound odd but your tv may be fine and the remote is causing your tv to be like that.
you should try changing the remote first ok! cause probably a diode is messing the wat your tv should work.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
278 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
