Question about IBM ThinkPad T30 2366 Notebook
Ibm t30 post beep error 1 3 3 1
Hi i have an ibm t30 2366 and i am getting a black screen with beeps the beeps are paired 1 - 3 - 3 - 1. if anyone has a fix for this i would be beyond greatful. i have tired other ram and before this happened my 512 suddenly started showing as 256.
thanks
  • 2 more comments
  • jokiu Nov 05, 2008
    i have a same problem.. now i know what it can be,.. but.. How can i fix it?? thnx for help
  • snoppyman Jan 13, 2009
    My IBM T30 2366 just started doing the same thing. I was up all night trying to figure out if it was the stick or the possibly solderabilty. This has proved my theory correct. Both sticks will run the PC in slot 1. Guess I will just buy a 512 instead of 2 256 sticks.
  • IBMPC Jan 20, 2009
    even i am facing the same problem. i am unable to see anything on the screen. i am able to hear 1-3-3-1 beeps and the system is restarting automatically. this happens for the long time. please solve my problem. Thanks in advance.
  • NARF86 Apr 25, 2009
    ****,same things with a T30 type 2633,happens 1-3-3 beeps in DIMM 2 whit both modules,but with DIMM 1 no beep,no post,no nothing
    so maybe mainboard is damaged,but ill try with other modules,maybe this ones are bad
  • 3 Answers
T30's do have a well reported problem with their memory slots. It is possible to fix it if you are brave and moderatly competent with a low-power (15-20W) soldering iron with a good bit (I recommend a flat oblique tip of about 2-3mm, not a pointed one).
Firstly, heat the soldering iron and clean all traces of solder from the bit. You can use a wet solder sponge, or even damp kitchen paper. It is VITAL to remove all solder.
Remove power and battery from the T30. Open the memory cover, and remove all memory.
Taking great care, press the bit of the hot iron with moderate pressure (about twice what you would use to press a key with one finger) on each pin in turn for about 1 second, on the contacts of the memory slot that is not working. Because you have no solder on the tip, it does not matter that you touch more than one contact at a time, but there are very small surface mount capacitors between the sockets. Be careful not to touch and unsolder these.
There is a warning here. Do no wipe the iron across the contacts. Always lift the iron before pressing it on the next pin(s). If you do wipe iron across the contacts, you WILL bend and short them. These are surface mount components, and the wire contacts are easily disturbed and shorted. If you do short the contacts, it will be difficult or impossible to fix.
Remember there are pins on both sides of the memory socket. Do not worry if some of the plastic of the socket melts, it is not a problem.
Continue until you have worked on all of the pins. Patience is a virtue here. Allow to cool, re-assemble and test.
I cannot promise that this will fix your T30, but I have extended the life of 2 out of 3 T30s I worked on in this way. Note extended, because the design flaw will cause the problem again sometime in the future. The board appears to flex, which puts strain on the solder joints.
Posted on Sep 12, 2009
  • 3 Answers
Alternate solution to my last one.
Take the memory cover off. Press on the plastic of the memory socket that you believe is faulty. Power on the T30.
Try applying pressure at different points. If you find a point that allows the T30 to power up properly (I've found on mine that it is almost always at the end close to the edge of the T30), try finding something un-compressible about 0.75-1mm thick, and place it on the sensitive point, and close and memory cover. A piece of an ice-lolly stick may be about the right thickness.
If you use something compressible (like hard rubber sponge), it may work, but over time will become less effective as it becomes squashed.
I've noticed that the 1-3-3-1 error is a no-memory error detected by the BIOS POST. If you can make the memory work with pressure, once it gets past the Thinkpad splash screen, it may be that you can release the pressure. I can on this T30 I am currently using.
If you read my previous solution of soldering the sockets, then you can safely assume that the pin that needs soldering is very close to where you apply the pressure. This may allow you to re-solder fewer pins.
  • 300 Answers
Error means faulty dimm or system board, see link below -
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42323
Posted on May 24, 2008
1331 no ram seen , try putting one chip in slot one,closes to the middle ,take apiece of cardboard and push in,turn on if it works you have solder issues,I have seen ebayers that will resolder ,flux them $60 good luck if you only have one bad one a 1g chip in the other TA72
Posted on May 01, 2009
    Problem Solver:
  • 14 Answers
Ya eee, The infamous IBM / Lenovo T30's have a built- in fault !!
They forgot to properly solder in BOTH memory bays !!
ONE bay will support a total 512 Gb, but don't count on the OTHER BAY to show ANYTHING !! Check it out with PROPER MEMORY, I betcha will find me correct....Been there, done that !!
NOTE: stay away from any IBM / Lenovo laptop from T30 on up..(Made in Chinko- Land...) !!
The Chinese have learned to COPY American Technology, but not to DUPLICATE it...!!!
Posted on Dec 16, 2008
  • Douglas Robertson Jan 13, 2009
    Yes, the Chinese are building BIG BLUE's laptops, and as the man says. t#o on up are PURE GARBAGE... BEEN THERE , many a time...T30 is a great machine...when it worls, when it likes BOTH MEMORY SLOTS !!! Dugal
1331 beep code driving me nuts..took a suggestion on a whim (why not? nothing else worked)..removed memory cover and stuck a folded up paper towel in and reapplied the cover..IT WORKED! GO FIGURE!
Posted on May 15, 2010
  • 4 Answers
I had same problem on T30... I was only able to get memory Slot 1 working again. using pressure on the memory chip. I put a wad of that poster-sticky-plasticine stuff on the chip and then pressed the cover back on. So far so good, after a month it seems to be keeping the chip securely in place.
Posted on Dec 06, 2009
My thinkpad makes 1 beep followed by 3 more other beeps. Nothing shows up on the screen
I'm fairly sure this means there is some error in connecting with the screen, maybe a cable worked loose maybe the screen is dead, or maybe screen inverter or backlight dead.
Mar 25, 2010 | IBM ThinkPad T30 2366 Notebook
When i turn it on i hear it start, then i hear beep,pause then, beep,beep, beep, and this reapeats but the screen never turns on. i have unplugged it and restarted many times but the screen never turns on...
Hi
Thank you for your query
The beeping description you have provided is a motherbaord beep code
unfortunately there is not much we can do over this email
The code indicates that there is a issue with the motherboard
The laptop will need to be booked into a reputable PC shop for further investigation
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 22, 2010 | IBM ThinkPad T30 2366 Notebook
Thinkpad T30 no video no post no beeps
try to reseat memory ot leave one memory behind
Oct 10, 2008 | IBM ThinkPad T30 2366 Notebook
T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Aug 30, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Jan 03, 2008 | IBM ThinkPad T30 2366 Notebook
Laptop problem
1 long beep + 2 short beeps during a POST (Power-On Self Test) for a IBM ThinkPad stands for System board, video adapter or LCD assembly failure.
Dec 27, 2007 | IBM ThinkPad T30 2366 Notebook
Laptop won't turn on
Linux and UNIX curl command help If a redirect takes curl to a different host, it won't be able to intercept the user+password. ..... --tcp-nodelay, Turn on the TCP_NODELAY.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | IBM ThinkPad T30 2366 Notebook
Beeping noise and blank screen
The beeps are part of the POST (Power On Self-Test). Here's a link to the Lenovo site that might help you interpret the beeps you're hearing:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46018.html
Good luck.
Nov 19, 2007 | IBM ThinkPad T30 2366 Notebook
Start up problems
Normally 3 beeps then 1 is a checksum error, which is related to memory size/types and/or timings being reported as an error in the bios. Try also running in safe mode (F8) on start up and see if you get the beeps; because being able to start it up with an external monitor may mean that the memory error is related to amount that is used for your integrated graphics or a graphics driver error.
Dec 14, 2006 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
8,091 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
