How start lighting pilot - Heating & Cooling
  • 144 Answers
Turn switch at gas valve 2 hold buttton down 3 with button held down light pilot or push spark button 3 times and continue to hold button down for aleast 1 minute then let off button turn to on position
Posted on Sep 29, 2010
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Why won't it start?
Honda Pilot 2005 won't start dead starter - YouTube
? 2:48
https://www.youtube.com/watch?v=tH2rEYLbQrY
Sep 15, 2011 - Uploaded by Alexey Gavrilov
Honda Pilot 2005 won't start dead starter ... How To Replace a Starter 2006 Honda Odyssey -EricTheCarGuy ...
Today my Pilot won't start! - Honda Pilot - Honda Pilot Forums
www.piloteers.org > ... > General > Problems
Mar 13, 2011 - A half-hour later, I got in to move it back, and the Pilot would not start. All the .... Most original batterys from 2005 need to be replaced by now. Starting Problem 2005 EX
Feb 24, 2011
Cold Weather (0 deg F) 06 Pilot won't start after jump - Honda ...
Jan 17, 2009
Engine won't start - clicking sounds and guage flutter - Honda ...
Dec 23, 2007
Starting Problems
Mar 24, 2006
More results from www.piloteers.org
Thread: '05 EXL won't start - HondaSUV.com Forums
Jan 01, 2016 | 2005 Honda Pilot
HEATER WILL NOT STAY LIT
this happened to me as well. my pilot light had 3 settings.
"off" which is in the middle.
"up" is for priming/starting the pilot light.
"down" is what you move it to AFTER the pilot light is lit.
prior to lighting the pilot light, I had get city get city to verify gas was coming into house. It was not. someone thought they had turned gas on, but in fact did not.
so I had two problems.
Oct 25, 2012 | Heating & Cooling
No Hot Water
Well, let's start the trouble shooting process with trying to get the pilot lit...
Have you removed the cover at the bottom of the heater?-- Can you see an pilot light inside?
If not, Can you try lighting the pilot-- and noticing how the pilot flam heats the little ThermoCouple (TC)?
Note: In order for gas to flow thru the main control valve, the pilot light has to be heating the TC-- to generate a voltage, that in turn allows the main gas valve to open.
Do you need help in getting the pilot light lit?-- do you understand the need to hold down the start button, until the TC gets heated up?
Let us know what you find
Mack B
Jan 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Th pilot won't start ,motor start but won't light the pilot
I have a Kenmore Series 80 (Model # 66812694, Stock # 66812) that will not start. The light comes on, but no power when you push the start button. I have checked the fuse box and everything is fine. I've also tried unplugging for 10-15 minutes and replugging it in, but no success. Any suggestions?
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Feb 10, 2008 | Pitco Frialator SG14 Deep Fryer
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
