Question about Hotpoint Aquarius WF000 Front Load Washer
REf: f10 error
Hi, read your suggestion about replacing touch pad, have tried to go through hotpoints site an I am unable to find the touchpad? any suggestions?
regards
George
  • 172 Answers
George,
The touchpad may come only preinstalled on the control panel. If that is the case the control panel will connect to the control with a ribbon. In that case you will have to get the entire Panel. If you give me your model # I can look that up for you and let you know prices, part numbers, availability etc. .. Thanks for the question and I hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
Gateway touchpad
Check the settings for the touch pad. Check device manager for errors with the touch pad. Reinstall the drivers for the touch pad.
Aug 16, 2014 | Gateway NV76R24u Core i5-3210M Dual-Core...
Hotpoint w640 F000 error code
see this mean :Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Read more: http://www.appliancepartspros.com/repair-help/hotpoint-fault-codes.html#ixzz2gUdlkOnE
Oct 01, 2013 | Hotpoint Aquarius WD640 Front Load...
I am not sure what model of Kenmore Gas Range I have but I get an F10 error and unable to turn on the oven.
Hello Edgar,
The F10 error code means that function key (bake/broil/clean ect) on the touchpad is defective. Sometimes just making sure that the ribbon cable on the touchpad is connected tight into the control board.
The error code could be cleared by pushing CANCEL/OFF button..if error code returns the touchpad would need to be replaced.
Gene...OldTech2332
Aug 22, 2011 | Kenmore Kitchen Ranges
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
Disable mousepad
hi,
try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Jul 05, 2009 | Dell Studio 1537 Notebook
Problem with touch pad & web cam
did you try FN+F8
you should have disabled your touchpad.
Try this
Nov 04, 2008 | Lenovo 3000 Y410 Notebook
Disabling touch pad
The touchpad should be able to be disabled through the BIOS.
Restart the computer, then push F10 to access the BIOS - if F10 doesn't work, try the other function keys and possibly the ESC key. You should find the option to disable the touch pad within the BIOS settings.
May 09, 2008 | Compaq Evo N610C Notebook
Hotpoint error f10 on model wt740
F10 us usually a stuck key on the keypad. Turn the power off to the machine or kick the breaker off, press each button a number of times to make sure they are not sticking. If you find one sticking try to pop it out. Turn the power back on and try to use it. If the f-10 code returns you will need a new touchpad. Good luck to you and I hope this helped you. Mike Anderson
May 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
