2008 Yamaha Yamaha G5 Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own a yamaha g5 2009 model, i want to change the rear tyre, shall i go for a bigger size, tell me the size which i should go for?
Anonymous
Level 3:
Guru:
  • Master 440 Answers
  • Posted on Sep 29, 2010
Anonymous
Master
Level 3:
Guru:
Answers
440
Questions
6
Helped
170015
Points
1314
Hi
Its best to stick with standard sizes as Yamaha put a lot of research into finding the best tyre sizes for each model
Ride Safe
Bike-Doc
1helpful
I have just bought xjr 1300 2009 what r the tyre pressures
We would advise that for your Yamaha XJR 1300 if on tyre sizes front 120/70 ?€" ZR17 58W TL (tubeless) and Rear 180/55 ?€" ZR17 73W TL the tyre pressures (set when tyres are cold) should be as follows:-
Front ?€" 36 psi (pounds per square inch)
Rear ?€" 36 psi (pounds per square inch)
What size tyres camaro 1997 3800rs v6
The wheels could have been changed on the car from the standard original factory set and hence the tyre size may not be the standard factory original size.
The size of the tyres on the vehicle now is moulded into the side wall of the tyres and is easy to read.
Check all 4 tyres because larger size tyres may have been fitted as a pair to the rear.
The size might read - for example 245 45 18 or 235 45 17 (there are a huge number of sizes for each model of tyre).
The first 3 numbers are the width of the tyres in mm eg 225 mmm or 235 mm and so on. The second 2 numbers are the tyre profile size or ratio (which can be 70 65 60 55 50 45 40 and so on. The third number is the wheel diameter size. If you have 18 inch wheels on the car the tyres will read 18 or if they are 17 inch wheels the tyres will read 17 and so on.
I have one Yamaha r15 can i swap wheels from r125 because it is bigger than r15
Unfortunately the you are constricted by the width of the swingarm.
The tyre size for the R15 is the optimum tyre size for performance although it does not look as good as chunky tires.
Isn't performance more important than looks anyway though?
Short answer to your question... No, this can not be done.
1helpful
Could you the tyre pressures front and rear for a kawasaki ninja 600 year 2000 please .thanks
hi, in there wisdome kawasaki played around with tyre sizes on the zx6r ninja,
tyre size rear 160/60/17.
tyre size front 120/60/17 1995-98 models zx600f
rear. 170/60/17
front 120/60/17 1998-2000 models zx600-g1
rear 180/55/17
front 120/65/17 2000-01 models zx600j
the only thing they didnt play around with is the tyre pressures all models front 36psi or 2.5 bar
rear 41psi or 2.9 bar
hope this helps and thanks for using fixya.
paul
6helpful
Tyre pressure front/rear ?
hi, the tyre pressures below are for the models outlined in brackets.
TDM 850, (A)(CH) 1996-2000, WITH TYRE SIZES FRONT 110/80/18 = 2.25BAR OR 33psi
REAR 150/70/17 = 2.75BAR OR 40psi
Can we change the size of rear tyre?
The tyre size is governed by the rim width and the space available in the wishbone. I would measure the space available for the tyres width right up inside the wishbone along with the tyre size that you have at present.
The tyre can be oversized but watch out for slipping on the rim of the wheel!
Consult a Yamaha Workshop for specialist tyre sizes and compounds. Pirelli make some super sticky tyres alowing for excellent high speed cornering!
6helpful
3answers
I wanna change the rear tyre of my R15... I am planning to put lil bigger tyre. suggest me the tyre size which will look good.. My friend had put MRF zapper 120/80 which looked little odd. Mechanics have...
You are governed by safety. The hub width will determine the maximum width and type of tyre as will the width of the rear suspension/wishbone.
Consult a qualified tyre fitter for accurate sizes. Don't forget your speedometer will no longer be accurate!
2answers
Is it possible for me to change the tire size of my 2005 lexus gx470 to a bigger tire?
yes it is just go to a tire shop that sells custom rims and tell them you would like to go bigger and they will tell you how big you can go ! hope this helps
2helpful
Tire size for a 2002 Yamaha Road Star Silverado
Front tyre dimensions: 130/90-16
Rear tyre dimensions: 150/80-16
5helpful
Can you tell me the tyre pressure on a fjr 1300 2005 also the amount of oil in the beveldrive and the amount of oil in the engine thanks
Front: 36psi
Rear: 42 psi
Beveldrive: 6.8 ounces
engine oil: 4.2 quarts (oil/filter change)
*Help me out. Rate me!
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
