Question about Recoton Advent Advent RCS110A Remote Control
Greetings I spilled water on remote. I believe it is all dried. a number of hours have passed. the red light comes on (left upper side) when any keys pressed. Will not turn on the tv. when tv is turned on manually the remote can not change channels. thanks for your help
  • Recoton Advent Master
  • 17,130 Answers
I have a universal remote. The power comes on, but I can't get it to work. It used to work until I spilled water on it. I know... Red flag. :) buuut I cleaned it up fast and like I said power still co
Since your remote is responding, you may want to check if it is producing an IR signal. To do this, take a picture of the remote when someone else presses a button. (Have the other person point the remote at the camera lens. With a digital camera (cell phone or other camera), if the remote is producing an IR signal, the resulting picture will show a flare of light.) Taking pictures of several different button presses may indicate which functions are compromised. You can try resetting the codes for the different devices the remote controls.
Unfortunately, you may need to replace your remote with a new one. I've never had much luck cleaning the contacts after they were damaged.
In the future, if you spill water on the remote, first remove the batteries. Then dry the bulk of the water off of the unit. To finish drying the water from the contacts inside, fill a bowl or other container large enough to hold the remote with some uncooked rice. Place your remote (with the battery compartment open) into the rice and leave it there; then cover the bowl. You can rotate the remote in the rice at intervals but leave it in the rice for several days. (The drying process can take a week.) Do not replace the batteries until the remote is completely dry.
Alternatively, get one of the cell phone drying bags and use that to dry the remote. It will still take several days to get all of the moisture out of the unit.
I hope this helps.
(If you aren't in a hurry, sometimes letting the wet gadget dry in the open air for several weeks will work. Trying to rush the drying process doesn't work as well.)
Dec 08, 2012 | Televison & Video
I got water on the front digital panel and now the oven doesn't want to start
you must try to dry with air pistol over the digital pane about 6" from distance. and let it dry. Wait for 24 hours.try to put some i.red lamp by 6 hours over night.with the same distance.
Try again. if the problem persist call to tech profession for test the keypad and control board are faulty and replace it.
God bless you
Oct 03, 2012 | Kitchen Ranges
Leak under car on driver side maybe waterpump
If the fluid is a bright green or yellow colour, it is coolant fluid. Check the water pump, there should be a seal leak drain hole under it, look for signs of a leak. If there is a green/yellow track leading from below the water pump. you need to have the water pump replaced. A leak from the engine would be dark brown to black an a transmission leak would be red tp very dark red. Coolant would tend to dry up while oils spills do not. The water pump is located on the side of the engine where the belts are. I do not know if your car is left or right hand drive.
Apr 10, 2011 | 2002 Ford Taurus
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
How to get to the drain line on my Frigidaire side by side refrigerator model number MRS22WNGW7. Water keeps coming out of the freezer side onto the floor (front left side). I was told it could be a...
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
May 14, 2010 | Refrigerators
SUBZERO 695
try this... the water valve in your sub. is located in the upper part. ( close to the condenser fan motor. yes the new one.) tell your TECH to test the water dispenser and by pass the ice maker. the leak is on top part . running all the way dow. good luck.............................LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU.... THANKS
Jul 29, 2008 | Sub-Zero 695/O Side by Side Refrigerator
SONY TV
No horizontal (Hstop) Check Capacitors C515 and C516 and the Jungle IC What is your model number?
Dec 30, 2007 | Televison & Video
Water in the freezer
Drain needs be clean, Easy to say but is some work to do.
Oct 14, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Televison & Video Logo
150 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
